Replacing belts....UGH
Old May 2, 2008 | 05:32 PM
sneakelman's Avatar
sneakelman
St. Jude Donor '08-'09
Default Replacing belts....UGH
The wife drove the vette yesterday. When she called me last night(worked a double shift) she said, "the vettes making a noise." I told her I would check it out in the morning.
So I get home, start up the vette, and there it is, the infamous squealing upon start-up.
No problem. Run to Autozone, get two new gatorbacks, idler pulley, and new tensioner pulleys. I'll fix that sumumabeoch good!
Removed the alternator belt, started her up. Squeal is still there. OK, got her narrowed down. So I remove the A/C belt, replace both pulleys, and start to put the new belt on.
ARGGGGGGGG damdamdam!!!!!!! Who ever designed this should be drawn and quartered! Anyway, after about an hour and a half of trying to get this dam belt on from the top, the bottom, and the side. I FINALLY came upon a thought. Took the belt away from both pulleys, routed the belt on the crank and the A/C compressor, then squeezed the belts together with a pair of small channel locks. Took the tension off the tensioner, slid the belts between the two pulleys, and slowly let the tension back on while releasing the belts with the channel locks. Simple as can be.
Why didn't somebody tell me this first!!!!!!
Anyhow, got the alternator belt on without a hitch, hit the key, and all is nice quiet and smooth again. New belts, and pulleys, so she is all set.
Old May 2, 2008 | 05:45 PM
csexton's Avatar
csexton
Glad you got it worked out. Been there!
Chuck
Old May 2, 2008 | 08:58 PM
dobewillie's Avatar
dobewillie
good fix
Old May 2, 2008 | 09:06 PM
RoccoC5's Avatar
RoccoC5
I just replaced my a/c belt, but the water pump was off at the time so granted it was much easier. It's a pain otherwise.
Old May 2, 2008 | 09:32 PM
Bob CTS's Avatar
Bob CTS
Great to hear.
I fought the AC belt and I found that it was easier to put the belt under the tensioner, release the tensioner while belt is under it then flip the belt up on the idler. It was a pain, the main belt was easy though.
Old May 2, 2008 | 09:38 PM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
Not bad
Try doing one on a ProCharger with the A&A Bracket
Thanks,Matt
Old May 2, 2008 | 09:54 PM
sneakelman's Avatar
sneakelman
Originally Posted by madmatt9471
Not bad
Thanks,Matt
Got one I can borrow to practice on man?
Old May 2, 2008 | 11:35 PM
Thanks for the tip on installing the belts.
Old May 3, 2008 | 02:20 AM
DeeGee's Avatar
DeeGee
I have some belts waiting to go on. Great timing thanks.
Old May 3, 2008 | 05:31 AM
damilleniumboy's Avatar
damilleniumboy
My sinker car is squeak, squeak, squeaking too. There goes part of my weekend .
Old May 3, 2008 | 11:18 PM
robsc501's Avatar
robsc501
Default replacing belts
Hi There,
They can be a real pita.I know ran into the same problem you did.What a struggle.
Walked away for awhile.I think the key is to start the belt on the crank pulley first any way thats what I did & I used a helper to keep the tensioner compressed and I got it.
robsc501
Old May 4, 2008 | 07:22 AM
vetter79's Avatar
vetter79
Old May 4, 2008 | 07:26 AM
sneakelman's Avatar
sneakelman
Still waiting for that Procharger to practice on.
Old May 4, 2008 | 12:00 PM
Tigershark3's Avatar
Tigershark3
Replaced mine awhile back w/ the Gatorback and agree it was a Royal PITA mainly due to the location. Screwed around w/ it for an hour until I figured out that if I put it on the tensioner first, rotated the tensioner then slipped it under the top pulley all was good.
To Replacing belts....UGH
