130 psi???
Old May 5, 2008 | 12:52 AM
dfalliaux's Avatar
dfalliaux
St. Jude Donor '08-'09-'10-'11-'12-'13-'15
Default 130 psi???
Hey guys!
Farily new c5 owner here. Bought a c5 from a fellow forum member and all is excellent for the most part!
So it's a 98' vert and just this past weekend I noticed the oil PSI guage was topping out at 80 psi so I clicked over to the digital read and it said the oil PSI was 130? WTF? I've just had the oil changed etc. and all is reading well with the dipstick.
Any ideas?
Old May 5, 2008 | 01:02 AM
speedsk899's Avatar
speedsk899
Oil Pressure sending unit! Happens all of the time on the C5's....It is located behind the intake and the intake has to be pulled to replace it! If you do a search you will find plenty of info!
Old May 5, 2008 | 01:56 AM
dfalliaux's Avatar
dfalliaux
Cool thanks man! I figured it was a gauge malfunction.
Old May 5, 2008 | 02:02 AM
DeeGee's Avatar
DeeGee
Its a familiar problem here. The catch is that many members have changed the sensor only to have it fail again within a few weeks.
Heres the Tech Tip on how to change it:
https://www.corvetteforum.com/techti...=246&TopicID=1
This thread is a must read and shows how to relocate the sensor and also the easy fix that means drilling into the cowl to get access
http://forums.corvetteforum.com/show....php?t=1588172
Old May 5, 2008 | 02:56 AM
dfalliaux's Avatar
dfalliaux
Gracias Amigo!
Old May 5, 2008 | 05:06 AM
speedsk899's Avatar
speedsk899
Both are good ideas but I think by relocating it you are just making another point that has a potential to leak, and its not that hard to change.....also I just cant bring myself to cut a hole there! haha
Old May 5, 2008 | 08:02 AM
J S Machine's Avatar
J S Machine
St. Jude Donor '10-'11-'12-'13-'14-'15-'16-'17
St. Jude Knife Maker
When I was test driving C5's to buy one, over half of them I drove had the oil sending unit failure. The one I bought did too....
I used the method where you simply cut a hole under the wiper cowl - if you haven't already seen it. It was easiest for me and you can't tell it's been done afterwards. Some people frown at the idea of cutting on their car, but to me it was easier than pulling the intake and will make it a simple job for the next guy---if there is one.
Old May 5, 2008 | 09:43 AM
Junkman2008's Avatar
Junkman2008
At least with the relocate, it's a 10 minute fix in your Sunday best. If you buy a quality kit, there are no extra leak concerns.
Old May 5, 2008 | 04:24 PM
dfalliaux's Avatar
dfalliaux
Cool thanks much for the info guys! Much appreciated!
Old May 5, 2008 | 04:27 PM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
my 3rd one just died
Old May 5, 2008 | 04:29 PM
DeeGee's Avatar
DeeGee
Old May 5, 2008 | 10:32 PM
That would get old fast.
Old May 6, 2008 | 12:55 AM
Junkman2008
Did you tell any of the senders that you are a mod?
To 130 psi???
