When people complain about Z, they are making a mountain out of a mole hill.
ALL of the work is in the prep.
It depends on what kind of time and effort you want to invest.
At the least, everyone should own a PC7424.
A rotary will accomplish amazing results in the right hands.
After a car is prepped, the application of several coats of either Z5P or Z2P is a piece of cake.
This pic would have looked better on a sunny day.
I agree that Zaino is easy once you prep the car. Then again, anything that is good takes a little time. As far as looking flat, doesn't describe just what the problem is. If your paint has oxydized & looks cloudy, no wax will fix that. If you have too many coats of wax on top of each other, the care needs stripped & a clay bar treatment. If it is just dull from not taking care of the finish, a buffer & polishing (no wax) compound will be needed. If the finish has swirls, scratches and pits, it will need to wet sanded & then buffed with a polisher & compound then hand polished. Again if you want it right, it will take a little work. Good luck.
