changed plugs and wires
Old May 5, 2008 | 03:05 PM
98c5vjc's Avatar
98c5vjc
Default changed plugs and wires
searched forum for all info i could find,could not believe how much and helpful, thanks to all who take the time,other than #7 it went as expected,got thru it and can not believe difference ,98 coupe,auto ,blackwing 37000 miles bought last aug with 35000 thanks again i know this is just the beginning
Old May 5, 2008 | 03:08 PM
VinnyT's Avatar
VinnyT
What plugs/wires did you go with?
Old May 5, 2008 | 03:10 PM
MagRedConv's Avatar
MagRedConv
There is info on anything/everything associated with our cars, that's for sure.
Old May 5, 2008 | 03:12 PM
Nice going. This forum has a ton of information for DIY'ers.
Old May 5, 2008 | 03:24 PM
98c5vjc's Avatar
98c5vjc
went with ac iridium plugs and gm performance wires also on advice of forum, gene from partshouse
Old May 5, 2008 | 03:48 PM
VinnyT's Avatar
VinnyT
Perfect. That seems to be the best all around set-up.
Old May 5, 2008 | 04:34 PM
DeeGee's Avatar
DeeGee
I just did the same job. I hope you survived the ordeal better than I did. I have both arms in slings
Old May 5, 2008 | 04:47 PM
98c5vjc's Avatar
98c5vjc
wasn't as bad as i expected, did first plug and ran out to replace socket ,went much easier
Old May 5, 2008 | 04:52 PM
DeeGee's Avatar
DeeGee
Good plan. I wish now I'd had a swivel joint
Old May 5, 2008 | 06:09 PM
csexton's Avatar
csexton
Good work
Chuck
Old May 5, 2008 | 06:24 PM
shannanl's Avatar
shannanl
That one is a bi#%%! It took me longer on the one plug than all the others combined.
Old May 5, 2008 | 06:25 PM
RJ1AZ's Avatar
RJ1AZ
From: PHOENIX, AZ Yes, it's true. You are a good woman. Then again, you may be the Antichrist.
Just did mine too, Dave. I put on some blue 10mm vision motorsports wires. Thank god I bought a swivel. Even so, I left some skin behind when I was done.
Old May 5, 2008 | 06:57 PM
itzza427's Avatar
itzza427
The claim of 100,000 miles is rubbish,change them half or less. Setting is supposed to be.040,,,My car had 57k. the tightest gap was .060 and they ran .065 to .075 gaps. Fresh delco iridium and wires (I used M.S.D.) What a difference. I say this is one of the best "mods" you can do!!!
Old May 5, 2008 | 07:18 PM
VinnyT's Avatar
VinnyT
It helps a LOT to remove part of the EGR exhaust manifold crap. I take that off and it's a breeze.
Old May 5, 2008 | 08:45 PM
Silverbullet00's Avatar
Silverbullet00
From: Norman Oklahoma - The Only State in the Union with no Blue Counties!
My tuner put on MSD wires!
Old May 5, 2008 | 11:00 PM
itzza427's Avatar
itzza427
Don't know if I'd quit say it's a breeze but it is a major help!! (I think it's air injection) Of all things to happen I didn't get #5's boot snapped on good,,missed like crazy.had to get some where soon so i had to get that bugger while motor was hot.#5 is the one wrapped up and blocked by all the hoses and pipe of that system.Got it back on and man did it scream after that!!
To changed plugs and wires
