[Z06] Front license plate frames/covers - what do you run?
Old May 7, 2008 | 01:39 PM
YellowZed's Avatar
YellowZed
Default Front license plate frames/covers - what do you run?
I have not put a front plate on my car (although it is needed in MN), but feel pretty vulnerable everytime I see a cop. What options are people with front plates running (covers with openings, alternative positions, clear, clear with body color surround etc, etc). Not sure yet if I will actually fit one, but it would be good to see how others have approached this without using the nasty black GM frame.
Thanks.
Old May 7, 2008 | 04:24 PM
zo6lou's Avatar
zo6lou
Go to a Chevy dealer and get one of those black ugly frames for about 25 dollars, have it painted to match your color, then look at midamerica and get a snap in clear cover for about 20 dollars, put em together and on the vehicle, fits nice and looks nice and follows the nose contours
Old May 8, 2008 | 05:45 AM
buckster's Avatar
buckster
You can have a hideaway license,cut an opening in the stock cover and just have your numbers or name exposed,filler plate black or painted same as car,license bent and wrapped onto center skirt under bumper. Here the city cops can't bother with the time and paper work but the highway cops write tickets and the fine is $170 or so ! I have my personal vanity plate on and then covered with a clear contoured bubble.Just like stock but clear. But,when washed or in rain it must be removed and wiped inside.Kinda a hasssle but I like the fact it keeps the shape of the nose perfectly.
Old May 8, 2008 | 08:20 AM
tech43's Avatar
tech43
I have a hide away plate holder. Folds down and slides back under the bumper. It attaches under the front bumper and houses the front plate. I always drive with it tucked away and if I do run into "ociffer Jones" I say I forgot to flip it up after the last car show. They are about $30.00. I will take a pic of it later and post.
Old May 8, 2008 | 09:35 AM
Wah's Avatar
Wah
Old May 8, 2008 | 10:21 AM
rpanesar's Avatar
rpanesar
Old May 8, 2008 | 10:57 AM
FasterIsBetter's Avatar
FasterIsBetter
I had a "hide-away" cover on my '03 Z -- the original filler panel. I removed the screws at the bottom that hold it in, installed the plate, and then put the screws back in but not all the way. I then cut slits in the bottom of the filler panel just wide enough to slip over the shank of the screws. Put the top of the panel in the slot, push up on the bottom and snap the panel in over the screws, and presto! Hidden license plate. Want to display the plate? Panel snaps right out. Hide the plate? Panel snaps right in.
And don't worry about it falling out. I ran the car on many tracks with the panel in, and it never went anywhere. Held tight right where it is, even at 160 mph.
p.s. And the best part of this mod is the price. LOL
Old May 8, 2008 | 11:43 AM
Milan's Avatar
Milan
I hid my license plate too....in my garage that is.
Old May 8, 2008 | 03:38 PM
vettelover84's Avatar
vettelover84
I have my plate in my trunk, but I have the clear bubble just in case I have to put it on for good....
Old May 8, 2008 | 04:18 PM
LT1driver's Avatar
LT1driver
that plate hooked on lower spoiler would very likely get you a ticket in Texas and judge would side with law enforcement....covers or frames that cover state name or numbers illegal. Texas Law says plate must be visible from front and that is a subjective call, some get by with it on visor or dash, mostly depends on LEO. Old pick-um-ups seem to have no problem on dash but vettes better lookout for troopers. I just run the ugly plate and don't worry about it.
Old May 8, 2008 | 04:52 PM
slvrzo6's Avatar
slvrzo6
HERE'S MY FRONT PLATE!!
Old May 10, 2008 | 07:27 AM
Quick Silver Z's Avatar
Quick Silver Z
St. Jude 15 Year Donor
No-IL Events Coordinator
2025 C6 of the Year Winner - Unmodified
2019 C6 of Year Winner (appearance mods)
2018 C6 of Year Finalist
St. Jude Donor '12 thru '26
I run a front plate with the clear contoured cover, problem is now the cover is illegal here too! We just had a local speed shop open house and a LEO stopped by to hand out a dozen "no front plate" tickets!
Old May 10, 2008 | 10:53 AM
rmbtowing's Avatar
rmbtowing
I have both the plates on my car they just happen to be stacked on each other on the back. I'll pay the ticket if I get one Im not putting the front plate on.
Old May 11, 2008 | 12:17 AM
JETZ's Avatar
JETZ
Old May 11, 2008 | 08:44 AM
PerrinPhantomZ06's Avatar
PerrinPhantomZ06
Thats pimp
Old May 11, 2008 | 09:24 AM
Quick Silver Z
My "illegal" bubble...
Old May 11, 2008 | 10:07 AM
GeorgeZNJ's Avatar
GeorgeZNJ
St. Jude Donor '08-'09
If you install your front plate and take your plate cover(stock) you can mount it, I just leave the top two screws a few turns loose, push the cover up under the screws and pull it back down into place. Do not tighten the screws, this allows you to pull it off quickly to show the officer that the front plate is indeed mounted but you"forgot" to take the cover off. If you are not driving like an ***, and are courteous most officers will give you a break. This method has been tested numerous times deep into tripple digits at watkins glen, and has also been spin tested there.
To Front license plate frames/covers - what do you run?
Old May 17, 2008 | 12:30 PM
Rayboy1's Avatar
Rayboy1
I can't seem to convince myself to put that front plate on. I just moved to Texas from Louisiana where a front plate is not required anyway.
Old May 17, 2008 | 01:24 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
None, I had it filled in on my wide body kit.
Old May 22, 2009 | 02:21 PM
divo's Avatar
divo
Default front license plate frames
Anyone know how to remove the front frame from a C5? back was easy but can't figure out thre front
divo
