Service Colomn Lock
Old May 7, 2008 | 07:08 PM
lamb-chop's Avatar
lamb-chop
Default Service Colomn Lock
My newly purchased 2001 vette has been displaying "service colomn lock" on the digital readout under the gauges. Yesterday the car wouldn't start, as though I wasn't pushing in the clutch. Plenty of volts, yet no cranking. The dealership told me to unplug the battery to reset the computer, because apparently it has something to do with a security interlock. Are these issues related? If so, what is the estimated cost and time off of the road?
Old May 7, 2008 | 07:25 PM
Chicago's Avatar
Chicago
St. Jude Donor '15
50 bucks for a column lock bypass, and about 1/2 hour of your time is all that's needed to fix this very common C5 problem.
Old May 7, 2008 | 07:29 PM
Bob CTS's Avatar
Bob CTS
Yep huge sticky at the top dedicated to this.
Purchase and install the CLB from a Corvette's of Houston and your problem will be over. Do not trust the recalls that GM does because they simply do not work. I have been down that long and bothersome road.
Old May 7, 2008 | 07:34 PM
troopersheriff391's Avatar
troopersheriff391
Default column lock
I did everything that could be done. Took it to Dealership spent $300.00 and still had the problem. Had to have it towed 2 times. Got Column Lock by-pass from supporting vender $50 two years ago no more problems. Same the time and $$$$ get the by-pass. check out the sticky at top of fourm for weights will give you a lot of info about your new car. Good Luck
To Service Colomn Lock
