[Z06] Dam it car won't start!
Old Nov 25, 2009 | 12:14 AM
  #41
wildwall's Avatar
wildwall
Just went through this. As time went on, it happened more frequently. Turn the key, nothing. No codes were thrown showing the resistor was at fault. I changed the clutch switch, theft relay, ignition switch and did the vats bypass. All this I did myself and spent under $100. Only thing left is the starter, and if it happens again, I'll have the starter replaced. I have removed the vats and did the column lock bypass, which cost $50. Some may say the car is easier to steal, but I'll take that chance for the peace of mind of not being stuck by these two weak-*** attempts at theft protection!
Old Nov 25, 2009 | 12:33 AM
  #42
BobbyC3's Avatar
BobbyC3
From: Common courtesy and common sense are not common.
St. Jude Donor '09-'10-'11-'12-'13
Originally Posted by droid
So what is my next move? Done all and everything ya'll said. I still won't ****ing start with a brand new A&A blower.
DROID
So you have a new blower? I'd look at the A&A blower installation process
Old Nov 25, 2009 | 12:46 AM
  #43
wildwall's Avatar
wildwall
I'll bet he has it running by now- original post was may 2008!
Old Nov 25, 2009 | 12:52 AM
  #44
BobbyC3's Avatar
BobbyC3
I live in the past But my Z06 wouldn't start until I did the Radio Shack 2 dollar ohm resistor key lock bypass upgrade.
http://forums.corvetteforum.com/c5-t...-repair-6.html
