Rear Window Tint
Old May 8, 2008 | 11:03 AM
gray-c5's Avatar
gray-c5
St. Jude Donor '08
Default Rear Window Tint
I have had a bad experience with a window tinter (sanding rear window and air bubles in film) in Houston. I've had to replace the rear window as it was damaged by a tinter who claim to be the best. I've looked at the work done by a couple of others and they all have air bubles in the top of the rear window film. It seems the little black bumps on the glass don't let the film stick properly. Has anyone gotten a good job? Can someone recommend someone in Houston? Thanks.
Old May 8, 2008 | 11:06 AM
candacedianne's Avatar
candacedianne
I am in GA, but if you have a Line-X I would check them out. They did a great job on our car!
Old May 8, 2008 | 11:23 AM
gray-c5's Avatar
gray-c5
St. Jude Donor '08
Default LINE-X Spray-On Truck Bedliners ?
LINE-X Spray-On Truck Bedliners?
Old May 8, 2008 | 12:14 PM
superstreet's Avatar
superstreet
St. Jude Donor '10
The "black bumps" need to be very lightly rubbed over with a Scotch Brite pad. I stress very lightly or you will scratch the glass itself. Just enough to scratch the black so the tint will have something to adhere to. Make sure the the window is washed thoroughly with a mix of water and liquid dishwasher detergent to get rid of all the debris.
Or you can stop the tint about 2 inches into the black lines and apply black vinyl tape the rest of the way up. Obviously you won't be able to see thru the tape, but it is a minimal width of tape.
Old May 8, 2008 | 12:33 PM
MIKE-C5's Avatar
MIKE-C5
St. Jude Donor '05-'06-'08
I got mine done by Pro-Tint in Plano! !
One piece and excellent job by Claudio! !
Old May 8, 2008 | 12:43 PM
superstreet
St. Jude Donor '10
Make sure you/they heat shrink it too. No bubbles or "fingers" and in one sheet.
Old May 8, 2008 | 03:33 PM
gray-c5's Avatar
gray-c5
St. Jude Donor '08
Default Can anyone suggest someone in Houston
Can anyone suggest someone in Houston?
Old May 8, 2008 | 03:37 PM
candacedianne
Yeah, thats where my husband took it.
Old May 8, 2008 | 04:09 PM
jpandes's Avatar
jpandes
Sanding!@#?
The guy that did my rear window, used black vinyl to cover the "dot matrix" portion of the window. Tint won't adhere to it.
Old May 8, 2008 | 04:41 PM
Mike2013's Avatar
Mike2013
St. Jude Donor '03-'26
Do you have a 3M window tint shop near you? If you do check them out. 3M did mine, 1 piece, and a perfect fit.
slvrzo6's Avatar
slvrzo6
I Just had my Windows Tinted on my Z06.. I had those little Black Bumps on the Top of my Rear Window and my Guy said the only way he could do it and make it look A+++ is to Etch the Glass with Black Window Paint.. So the Top of my rear Window is Etched where the Bumps used to be. It looks just the like the factory Black border around rear window except the top border is a little bigger now. It looks Stock from the inside and outside. He just taped a clean line around the inside of the rear window, put clean drop cloths on the inside of my car and apply this etching with a small brush.. I'm loading a Picture below.. My car is Dirty!! So please excuse the Dust on the Windows I assure you it looks A++ Hope this helps..
Old May 8, 2008 | 04:55 PM
gray-c5's Avatar
gray-c5
St. Jude Donor '08
Default Can you recomend someone in Houston
Can you recomend someone in Houston, Texas ?
Old May 8, 2008 | 06:47 PM
TheRadioFlyer97's Avatar
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
I'm in spring (close to houston)
Mine was done by Xtreme Tinting: 20% rear dye based tint.
6700 Louetta Rd Ste A
Spring, TX 77379
281 374 9100
NO peeling or bubbles.
Old May 8, 2008 | 09:25 PM
J S Machine's Avatar
J S Machine
St. Jude Donor '10-'11-'12-'13-'14-'15-'16-'17
St. Jude Knife Maker
Mine has the dot matrix covered in black vinyl. the tint stops where the dot matrix begins and from there up its vinyl. I have never even noticed not being able to see out of it. guess it is negligible.
good luck
Old May 8, 2008 | 10:46 PM
Choreo's Avatar
Choreo
I had the same problem with bubbles in the dot matrix. so a couple months ago I removed the tint and started over. I taped off the dot matrix area and then painted it from the inside with Krylon black for glass - waited 3 days and had it re-tinted. Came out great this time.
Old May 9, 2008 | 03:31 AM
GMANS C5's Avatar
GMANS C5
I'm in Indy, but my guy did and awesome job.. all one piece, no vinyl... I'll get some pics up tomorrow.
Old May 9, 2008 | 09:37 AM
gray-c5's Avatar
gray-c5
St. Jude Donor '08
Default Still Looking
I went to a place yesterday after work that on the phone, said they do vettes all the time. Was not impressed when I got there. They basicially said all vettes end up with pealing and white spots after a year or two. I'm going to try the place that was suggested above (Extreme) and see what they have to say. Why do they put those dot matrix on the rear glass any way?
To Rear Window Tint
Old May 9, 2008 | 09:56 AM
superstreet
St. Jude Donor '10
Definately go somewhere else. I tint windows on the side and if you apply the tint correctly it won't peel and it will last for years. I have no idea what he talking about when he says white spots.
Old May 9, 2008 | 10:47 AM
gray-c5's Avatar
gray-c5
St. Jude Donor '08
Default White spots
White spots are caused by the film not sticking (air bubbles). Called the suggested (Extreme) vendor from above, and Rob said that the air bubbles were common on vette installations. He requires an appointment and the car ALL day. This is my only car and I would prefer not to spend all day at a tinter, so I'm still looking for more suggestions guys.
Old May 9, 2008 | 11:37 AM
bucwheat's Avatar
bucwheat
You can take a piece of black vinyl and cover the matrix dots,looks better than air bubbles.
