Sticky pedal?
Old May 9, 2008 | 07:36 PM
HOOBS's Avatar
HOOBS
Default Sticky pedal?
Has anyone heard the sticky pedal syndrome that gm had from about 99-02? Just like the "bouncing fuel gauge". If so about the sticky pedal what can you do to fix it? Doesn't stick to the floor but sticks a little before you depress it. Almost have to slightly double "tap" it before you accelorate. Thanks!
Old May 9, 2008 | 07:43 PM
vettes4fun's Avatar
vettes4fun
I've seen this with cars & trucks that use a cable to control the throttle body. The throtttle is controled by a wire on a vette so you should not feel anything.
