Differences in 3.42 differential?
May 9, 2008 | 10:08 PM
Will a 3.42 gear out of a manual C5 go into an automatic? I heard of some error codes caused by this combination.
May 9, 2008 | 10:10 PM
Yes you can use 3.42's in an A4, that's what I run. You just have to make the necessary changes to the program so your car will shift properly.
May 9, 2008 | 10:20 PM
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
Yes! I do as well!
But you will need to use a handheld tuner or your local tuner will need to make changes to the PCM
Here are the differences in the RPM's:
Quote:
Originally Posted by
DavzC5
Thanks,Matt
May 9, 2008 | 10:25 PM
Thanks guys. The picture says it all Matt.
May 9, 2008 | 10:31 PM
futuretech
don't forget to transfer the
seal plate from your A4 carrier:
to the manual carrier.
May 9, 2008 | 10:32 PM
Thanks Mike. You have been very helpful on some of my other threads!
May 10, 2008 | 02:17 AM
Thanks Matt, that chart is very helpful!
May 10, 2008 | 02:33 AM
EDenney
May 10, 2008 | 08:57 AM
I swapped the 3.42 out of my M6 C5 into my wife's A4. I reprogrammed the tranny pressures and shift points using EFI Live.
http://forums.corvetteforum.com/show....php?t=1753571
I bought new pieces from the dealer to add to the diff rather than pulling the one's off her car. Here's the plate.
The output shaft seal.
The large O-ring that seals the plate itself.
The plate installed.
May 10, 2008 | 10:10 AM
I just re-used the trans plate with new seals. Have not had a problem with it.
