Ipod mount
Old May 11, 2008 | 10:24 PM
RJ1AZ's Avatar
RJ1AZ
From: PHOENIX, AZ Yes, it's true. You are a good woman. Then again, you may be the Antichrist.
Default Ipod mount
Thought I'd share some pics of my Sunday project.
I've had this in mind for awhile and finally got around to doing it. I've had my Ipod holder mounted on my ebrake handle with some zip ties. Not very pretty, but having an automatic, I rarely use the ebrake and it was the perfect spot for it--i.e. within easy reach and not tossed in my cup holder or on the passenger seat, and not inside the console where the temps can get quite warm.
I saw this material called "kydex" that another member had used to do some custom work, and I figured it would be just the ticket for what I wanted to do. Now, I can slip the holder onto the ebrake whenever I take my Ipod with me, and remove it quickly when I don't want it on there.
Old May 11, 2008 | 10:28 PM
JeepTJ's Avatar
JeepTJ
St. Jude Donor '05-'06-'07-'08-'09-'10-'11
Sweet
Old May 11, 2008 | 10:34 PM
vettelover84's Avatar
vettelover84
Very Nice!!!
Looks like it belongs there!!
Old May 11, 2008 | 10:35 PM
CamachoSF's Avatar
CamachoSF
Gotta get one of those for my Zune
Old May 11, 2008 | 10:44 PM
jrprich's Avatar
jrprich
I like it
Old May 11, 2008 | 10:46 PM
Cozmo's Avatar
Cozmo
CentralTX Events Coordinator
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17
Cool idea. I have some Kydex in the garage but think I will do it a little differently.
Old Jul 1, 2008 | 10:37 PM
lil vette's Avatar
lil vette
Old Jul 2, 2008 | 04:21 AM
Mojo 97 Vett's Avatar
Mojo 97 Vett
Were can you find this Kydex stuff ? Would like to do that mod my self
Old Jul 2, 2008 | 04:53 AM
JACKAL0PE's Avatar
JACKAL0PE
Lepus-temperamentalus
http://www.interstateplastics.com/pr...x?search=Kydex
Old Jul 2, 2008 | 04:55 AM
JACKAL0PE's Avatar
JACKAL0PE
To heck with the kydex, where did you get the neat little holder?
Old Jul 3, 2008 | 01:11 AM
RJ1AZ's Avatar
RJ1AZ
That came along with my iSimple kit I picked up at Best Buy. Model ISGM73.
Old Jul 3, 2008 | 01:38 AM
veni vidi vert's Avatar
veni vidi vert
Great DIY mod.
If you don't mind me askin'
What thickness of Kydex did you use, and what measurements did you use before shaping it?
Old Jul 3, 2008 | 01:45 AM
Chicago1's Avatar
Chicago1
How did you shape it and after you shaped it how sturdy does it become? Never heard of that stuff before.
Old Jul 3, 2008 | 09:52 AM
MIKE-C5's Avatar
MIKE-C5
St. Jude Donor '05-'06-'08
looks good! !
Old Jul 3, 2008 | 10:04 AM
3318C5's Avatar
3318C5
Originally Posted by vettelover84
Very Nice!!!
Old Jul 3, 2008 | 10:06 AM
Cobra_4's Avatar
Cobra_4
St. Jude Donor '09
Nice, I may have to look into that.
Old Jul 3, 2008 | 10:09 AM
THE TECH's Avatar
THE TECH
Makes the handbrake hard to use it seems.
Old Jul 3, 2008 | 12:59 PM
RJ1AZ's Avatar
RJ1AZ
Originally Posted by Veni, Vidi, Vert
Great DIY mod.
I don't have my order form anymore so I don't know the exact spec, but it's appoximately 2mm thick or slightly less than 3/32". Overall measurements... it was about 7 3/4" x 3 1/2".
It's a thermo-formable plastic. You heat it (I did it in my oven) and it becomes sort of like inner tube rubber. I had removed my ebrake handle so it would be easy to work with, and just wrapped it with the kydex when it was hot enough to be pliable.
When it cools, it holds whatever shape you put it in and it's very sturdy. Here's a couple links I came across while trying to figure out how to work with it.
http://ajh-knives.com/miscellaneous.html
http://www.kydex.com/methods_Thermoforming.asp
Takes two seconds to slip it off the handle.
With an automatic, I rarely use the ebrake, so it's not an issue for me. MN6 guys would have to make the call on that one.
My first attempt at making a this was going to be hard mounted to the right of my radio and hvac, but the fit was too tight between the console bezel and the dash, so I came up with this. For me, it's the perfect placement, but I'm sure others will come up with their own solutions.
Old Jul 3, 2008 | 01:02 PM
xxSPEEDDEMONxx's Avatar
xxSPEEDDEMONxx
Crafty!!!
To Ipod mount
