View Poll Results: High Flow Cats - Necessary?
Necessary
52
67.53%
Not Necessary
25
32.47%
Voters: 77. You may not vote on this poll
POLL - High Flow Cats
Old May 12, 2008 | 05:09 PM
MagRedConv's Avatar
MagRedConv
Default POLL - High Flow Cats
I'm having LT's installed next month on my '98 w/80k and am now wondering if HF cats are necessary or not. I've searched this topic and didn't find anything directly relating to this so please chime in.
Old May 12, 2008 | 05:36 PM
GRUNIE's Avatar
GRUNIE
I'm not sure if they're necessary but to me, if you're putting on long tubes why stop there? Just make sure the cats you buy are quality set
Old May 12, 2008 | 05:59 PM
Chemdawg99's Avatar
Chemdawg99
St. Jude Donor '12 thru '21
Old May 12, 2008 | 06:14 PM
peter pan's Avatar
peter pan
Life Time NCM #2196
If you can get past the inspection do without them other wise then I would put them on and in Texas they may do a visual
Old May 12, 2008 | 08:17 PM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
On a stock set-up I would not even hassle with it!
Now if you are going to do Long Tube Headers then it is worth it and really is a good idea since many come as a kit and are simply just a bolt on set up!
Thanks,Matt
Old May 12, 2008 | 08:50 PM
moserbe's Avatar
moserbe
I live in Pa where emissions are visually checked. When I went with the long tube headers I also went with the hi-flo cats.
Old May 12, 2008 | 08:57 PM
MagRedConv's Avatar
MagRedConv
Thank you all for the insight, I have been struggling with this one for a few weeks.
Old May 12, 2008 | 09:23 PM
BOTYNV1's Avatar
BOTYNV1
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19
Old May 12, 2008 | 11:07 PM
itzza427's Avatar
itzza427
Necessary NO,,advisable YES. Stockers will work,,high flows are much better!! No cats,stupid and irresponsible!!(unless it is a track only car that you tow to the track)
Old May 13, 2008 | 12:20 AM
crazyv6's Avatar
crazyv6
You won't lose anything by adding them. Quality cats flow like straight pipes.
Just for the record I run Random Techs with LTs and Corsa cat back.
Old May 13, 2008 | 01:20 AM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
Do you have a list of tracks that are isolated from the same atmosphere the rest of us live under?
If no, what's the difference?
I mean, You say I need to trailer my catless car 6 miles to the local track, but you have no problem if I run it WOT for 50 miles there? Does that make any sense at all?
It sounds like you're trying to be politically correct, but have no idea why.
Old May 13, 2008 | 07:02 AM
ecoman's Avatar
ecoman
Good point
Old May 13, 2008 | 07:16 AM
Glennm27's Avatar
Glennm27
2017 C7 of the Year Finalist
St. Jude Contributor
I had LG Long Tubes on my 02 coupe with Random Tech hi flow cats. I put them (cats) on becasue back in 05 I was feeling as you are now, not 100% sure, should I or shouldn't I.
After driving those 3 years with them I realized they were a big waste of money.. There is absolutely no need plus they are not cheap.
If I were to do it again, I would NOT put cats on the car.
Old May 13, 2008 | 07:21 AM
Glennm27's Avatar
Glennm27
Please don't think that the use of hi flow cats is being "responsible" as mentioned above.
I was not only able to see straight through a brand new Random Technologies Hi-Flow cat but I could make out exactly what I was looking at on the other end. They are about as useful as a hood seal on your Corvette.
Old May 13, 2008 | 07:30 AM
Glennm27's Avatar
Glennm27
Old May 13, 2008 | 07:51 AM
NCSU's Avatar
NCSU
Mine w/o cats makes the exhaust smell pretty bad - enough to make me smell like fuel every time I drive the car. I've got a new setup in boxes, and SLP high flow cats are inlcuded.
Old May 13, 2008 | 08:02 AM
Chemdawg99's Avatar
Chemdawg99
I am posting this FAQ I came across for the the OPs information purposes only. Before I get attacked as a "tree hugger" let me just say that my position is to do what you know you can get away with in your area. I don't race my car like many of you do, so keeping the OEM converters are not an issue for me. In general, only a handful of states operate to California emissions standards. High-flow cats and LT headers are not considered street legal per federal regulations, so like Peter Pan said, if your state does not do visuals, go for what you can get away with, but be careful.
http://www.racingbeat.com/emissions.htm
Peace
To POLL - High Flow Cats
Old May 13, 2008 | 08:25 AM
3318C5's Avatar
3318C5
sometimes the question of needed is probably more based on your states regulations more than anything else. The technology today has gotten very good, and most high flow cats are of a flow thru design.
I personally went with LG pro's and no cats. Looking back I would probably have gone with cats. The sound is amaizing, but like mentioned above I smell like gas after a long time in the car. Good luck!
Old May 13, 2008 | 08:46 AM
Chemdawg99's Avatar
Chemdawg99
More information for the OP. The website for Texas emissions testing by county. Travis County does do emissions testing. Hope it helps EDIT: it would appear that some counties are more stringent than others, including Travis County.
http://www.txdps.state.tx.us/vi/index.htm
Old May 13, 2008 | 09:12 AM
Glennm27's Avatar
Glennm27
After reading some of the replies after mine, maybe I'd change my opinion. If not having cats is going to make you smell gas inside the car and make you smell like gas after driving, then THAT would be enough to make me stay with the cats on my car.
I am glad I heard this info. I never heard this before......
