0410 code help needed
Old May 12, 2008 | 08:09 PM
bonrox's Avatar
bonrox
Cruising
Default 0410 code help needed
I have a 0410 error and I am looking for ideas on what to try now. It's a 2004 C5 convertible. All that I have is a set of 97 C5 manual to guide me. According to the schematic, I am suppose to have a relay #40 and there is none in the box, but when I look at the box index on the fuse box, the 04 is not suppose to have it, so I don't think that is the issue. They may have changed that since 97.
The injection air pump does run for about a minuite or 2 on startup. After the engine warms up, about 5-10 minutes, the error code comes on. After cooling down, the second startup and warmup, forces the check engine on.
I also checked the air hose and air is coming out after the T. I am not posting a 1415 or 1416 code also.
So where do I go from here???
Old May 12, 2008 | 08:17 PM
CCA Corvette Parts's Avatar
CCA Corvette Parts
Premium Supporting Vendor
St. Jude Donor '07-'08,-'13-'14, '16-'17
Screw on your gas cap...
Peace
Chip
__________________
..................Click for
Old May 12, 2008 | 09:14 PM
dobewillie's Avatar
dobewillie
good starting point good luck
Old May 12, 2008 | 10:41 PM
robsc501's Avatar
robsc501
Default Code p0410
Hi there,
Your one way check valve is probably stuck closed not allowing air into the exhaust system.Their are 2 in the AIR system. One for the left bank of cylinders & one for the right bank of cylinders.Have you just installed a set of headers recently? Please fill out your profile as a cold climate & humidity affects the air pump operation.(moisture) The gas cap has no effect on this problem.Reset this code & see if it goes away.I doubt it will.
Check this site out for in depth info: www.obd-codes.com/p0410
keep us posted.
robsc501
Old May 13, 2008 | 02:17 AM
bonrox's Avatar
bonrox
Cruising
Originally Posted by robsc501
Hi there,
keep us posted.
robsc501
I pulled the left bank valve and it appears to be ok. The right one requires me to pull the intake and I did not check that one. But if that one was stuck, I would assume that I would pop a 1416 code.
The car is stock also.
Old May 27, 2008 | 10:01 AM
bonrox's Avatar
bonrox
Cruising
I finally sent it to GM. The issue was a broken vacumn line underneath the battery. $217 to troubleshoot it and fix it.
Oh well, at least it is done.
Old May 27, 2008 | 05:41 PM
robsc501's Avatar
robsc501
Hi Bonrox,
Glad to hear the problem is solved & no intake removal required.Was that a look & see or did the tech. use a scanner tool to find the problem.That should be the rt.side vacuum line coming off your AIR pump. You must have had a battery leak at one time in that area. $217 is not bad at all.Mark that one down in your log book.
robsc501
To 0410 code help needed
