[Z06] New track setup. CCW's
Old May 14, 2008 | 10:11 PM
Z06Fix's Avatar
Z06Fix
Default New track setup. CCW's
17x10 front 17x11 rear CCW classics T1 spec.
295/35/17 front 315/35/17 rear Hoosier A6's
Got the hoosiers mounted up and decided to take a couple pics. This will be my autox/HPDE setup. I can't wait to get it back on track
Old May 14, 2008 | 10:17 PM
Crowder13's Avatar
Crowder13
looking good eric
Old May 14, 2008 | 10:29 PM
IMXCITD's Avatar
IMXCITD
Old May 14, 2008 | 10:33 PM
JerryX's Avatar
JerryX
Old May 14, 2008 | 11:39 PM
Cobra4B's Avatar
Cobra4B
CI 3-5-6-7-8 Veteran
They look awesome.... I've had classics since '03. You'll fine A6s run out quickly with HDPE use, you want R6s for track events.
Old May 14, 2008 | 11:45 PM
Steve Theodore's Avatar
Steve Theodore
Nice and aggressive!
Old May 15, 2008 | 08:44 AM
AlwaysInBoost's Avatar
AlwaysInBoost
looks good.
do you have any pics from the side showing how much the rims/tires stick out?
Old May 15, 2008 | 08:59 AM
Z06Fix's Avatar
Z06Fix
Originally Posted by AlwaysInBoost
looks good.
Only shot I have right now.
Old May 15, 2008 | 09:00 AM
Z06Fix's Avatar
Z06Fix
Thanks guys. I have wanted a set of CCW's for almost 5 years now. I'm finally able to get a set of my own. Feels pretty good.
Old May 15, 2008 | 09:06 AM
AU N EGL's Avatar
AU N EGL
Old May 15, 2008 | 12:22 PM
Independent1's Avatar
Independent1
St. Jude Donor '08
looks
How is the fitment of the 295s in the front. I have been toying with the idea of running 295s all the way around.
Of course I have to put my car back together before I can do that.
Old May 15, 2008 | 12:41 PM
mac_05evo's Avatar
mac_05evo
Old May 15, 2008 | 12:58 PM
Z06Fix's Avatar
Z06Fix
Originally Posted by Independent1
looks
295's fit perfect. No rubbing even at full lock. Of course my car isn't slammed either. One thats dropped all the way on the stock botls might have an issue.
Old May 15, 2008 | 01:03 PM
Independent1
St. Jude Donor '08
^^Thanks!
Old May 15, 2008 | 01:04 PM
LinearX's Avatar
LinearX
The car looks slick, Eric!
AU N EGL's Avatar
AU N EGL
For best handling in auto-x and on the road course, you dont want to lower any more then 1./2" from stock right heights. The is a lot of spring shock compliance on tight corners even with stiff suspension
Old May 15, 2008 | 03:02 PM
Z06Fix's Avatar
Z06Fix
Mine is droped about 15mm from stock. We droped it till the a-arms were parallel. On the scales its just about perfect.
To New track setup. CCW's
Old May 15, 2008 | 04:58 PM
AU N EGL's Avatar
AU N EGL
With you in the drivers seat?
Old May 15, 2008 | 05:09 PM
Z06Fix's Avatar
Z06Fix
Yes, I was in it while it was on the scales. It's pretty close on the cross balance. I may get it up to Phoenix Performance next year and have them make it perfect. I just didn't see the need till I had some seat time in the car.
Old May 15, 2008 | 06:16 PM
MUKAK's Avatar
MUKAK
