Old Mar 6, 2015, 05:18 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: General How-Tos
Print Wikipost
c5 secrets un-covered
Old May 15, 2008 | 11:15 AM
CanadianVetster's Avatar
CanadianVetster
Default c5 secrets un-covered
I saw a post recently with a list of "secrets" on the C5.
i.e.:"competitive driving mode",
How to release a vert. trunk with car running (pull emer. brake), and a list of other stuff..
Well I can't find agian.
Did any bodyelse see it, or have discovered interesting things not shown in the manual...
Do tell!
Old May 15, 2008 | 11:19 AM
merlin5353's Avatar
merlin5353
St. Jude Donor '07-'08-'09-'10
Old May 15, 2008 | 11:22 AM
VinnyT's Avatar
VinnyT
The little yellow “helper light” on the bottom of the rear-view mirror that illuminates the shifter area.
● That you can put your key in the driver’s door and turn it twice towards the front to unlock the passenger door and a third time to pop the trunk.
● That you can pop the trunk and also pop the gas cap cover by pulling on metal lines hidden in the back.
● The little slotted cover on the dash behind the steering wheel is where the inside air temperature sensor is located.
● All of the option codes are in the glove box.
● Tire inflation recommended pressures are on the driver’s door.
● The thing that looks like a little LED near the DIC buttons is a light sensor.
● The thing that looks like a little LED near the defroster vent is a UV sensor for determining A/C usage to compensate for the heating effect of the sun.
● The build sheet is in the front re-bar.
● If you leave your turn signal on, in about 1 minute it will start to ding (loud enough to hear over the stereo) to let you know you have old timers disease.
● You can reset the oil life by pumping the gas pedal 3 times (but not with the engine running).
● Hold down the reset button while on one of the trip odometers and it changes that reading to the miles you’ve traveled since last starting the engine.
● Hold down the Active Handling button for 5 sec. to engage “Competitive Driving” on cars equipped with active handling (2000 and previous years must be stopped.)
● If you pull the seatbelts all the way out while you’re buckled in, they ratchet back in to hold you tighter into the seat. (then move the seat forward to make it extra snug -- Leafty)
● Simply remove fuse #2 under the hood and your DRLs will be out permanently. Only thing affected is that when you unlock at night using the key fob your front turn signal lights and back up lights will not flash. Your front turn signals will operate normally, however.
● The side-view mirrors can twist both forward and backward, decreasing the chance of damage if struck.
● There is a release opening with a flap to let air out of the car when the hatch is closed. It is located just above the driver side rear compartment behind the carpet and on the side of the car. Not that it really works well.
● Also you can ground your amp to a screw/bolt that holds the rear middle compartment to the frame.
● If you have a 6-speed car you can pop the trunk when the car is running by lifting the e-brake.
● There is a spot on the driver side just out of the middle compartment under the carpet for the lug nut key. You should have a compartment on the drivers & passenger’s side (in the trunk) and a center compartment. On the left (drivers) side of the center compartment, on the left side where the center cover fits, there is an ‘indent’ that holds the wheel lock key.
● If you turn on the headlights, then go to parking light position, the lamps remain up but the headlights are not left on.
● If you have the passive entry feature: If you lock the keys in the car, wait a few minutes and then shake the car. That will unlock the car.
● HUD has a shift light for the manuals.
● You can easily shift the M6 trans up or down without the clutch if you match revs. (Not great for longevity, however.)
● You can eject the cd from the in-dash player without turning on any power. Don’t even need key in the ignition.
● The cruise will disengage if you purposely make sharp side to side turns while cruising at say 60-80 mph.
● When the engine is shut off, you can get the odometer reading by turning on the parking lights.
● You can program setting #3 (both memory buttons at once) in the seat memory to run the seat back and steering wheel forward for getting in/out of the car with the engine running.
● If you hate DRLs you can pull the e-brake ONE click and they go off.
Old May 15, 2008 | 11:36 AM
merlin5353's Avatar
merlin5353
Sounds great... any more??
Old May 15, 2008 | 02:27 PM
gray-c5's Avatar
gray-c5
St. Jude Donor '08
Default Cool
Hum, what about when you change a battery, ... does not seem right.
I'm going to have to look for it. Makes sense though
Per Owner's Manual "Notice: If you ever lock your keys in your vehicle, you may have to damage the vehicle to get in. Be sure you have spare keys. If you ever do get locked out of your vehicle, call Chevrolet Roadside Assistance. See Roadside Assistance Program on page 7-6 for more information." And
" The system has a feature that makes it difficult for you to lock your key in your vehicle. If you leave your key in the ignition and attempt to lock the doors, the vehicle will not lock and a chime will sound to remind you that the key is in the ignition. If the door lock is pressed again, within five seconds, the doors will lock and the keys can be locked in the vehicle. This system cannot guarantee that you will never be locked out of your vehicle. Always remember to take your key with you."
Old May 16, 2008 | 11:48 AM
BUGZ's Avatar
BUGZ
Where is the front re-bar??
Old May 16, 2008 | 12:16 PM
gray-c5's Avatar
gray-c5
St. Jude Donor '08
Default Good Question
Old May 16, 2008 | 12:19 PM
lil vette's Avatar
lil vette
BUGZ's Avatar
BUGZ
I found the answer. Do a "rebar" search. You have to pull the nose of the sucker to get at it. Or buy one from at the Corvette Museum
Old May 16, 2008 | 05:37 PM
C5XTASY's Avatar
C5XTASY
Try this: put the key in the driver's side door and turn to OPEN once to unlock the driver's door, twice to unlock both doors, and three times to pop the hatch (at least on a coupe). Never have seen the hatch one in print before. I discovered it by accident.
Ed
Old May 16, 2008 | 06:05 PM
Pseudomind's Avatar
Pseudomind
Do tell!
Look here
Old May 17, 2008 | 08:51 PM
HT1663WB's Avatar
HT1663WB
Right behind that piece of styrofoam.
Old May 17, 2008 | 10:27 PM
4deatr's Avatar
4deatr
This was great
Old Nov 7, 2008 | 12:57 PM
thutch26's Avatar
thutch26
how do you get rid of the 1to4 shift on the manuals?
Old Nov 7, 2008 | 01:09 PM
VetteHunting's Avatar
VetteHunting
Skip shift eliminator. CAGS bypass I believe.
Old Nov 7, 2008 | 01:22 PM
C5C6Norm's Avatar
C5C6Norm
From: Lower, Slower Delaware, formerly from Mobtown, MD (Baltimore)
Nice job, thanks for the info.
Old Nov 7, 2008 | 01:28 PM
vettelover84's Avatar
vettelover84
Have your tuner take it out.....
To c5 secrets un-covered
Old Nov 7, 2008 | 04:23 PM
HillcountryMac's Avatar
HillcountryMac
3● Hold down the Active Handling button for 5 sec. to engage “Competitive Driving” on cars equipped with active handling (2000 and previous years must be stopped.)
What is competitive driving?I thought that was "sport" setting.How are they different?
DeeGee's Avatar
DeeGee
You'll find those secrets and many more if you check out Leaftye's sticky at the top of C5 General. Its a mine of information
http://forums.corvetteforum.com/c5-g...ngths-etc.html
Old Nov 7, 2008 | 04:26 PM
DeeGee's Avatar
DeeGee
Here you go:
Competitive Driving Mode
The Corvette Active Handling system will be the first of its type to offer dual mode operation. In addition to an "OFF" mode, in which Active Handling is disabled, the system also allows the driver to select a "COMPETITIVE DRIVING" mode for autocross or gymkhana competitions. In this mode, the Active Handling system remains fully-functional -- measuring steering, yaw rate and lateral acceleration inputs as well as applying individual wheel brakes as required -- but the traction control system is disabled, allowing for some wheelspin and oversteer that skilled drivers often find beneficial in competitive driving.
Summary of Active Handling System Modes
• ON - Active Handling is automatically enabled when the car is started. This is also true of the ABS brake and traction control systems.
• OFF - Like traction control, the Active Handling system may be manually turned off if the driver so desires. This is not true of the ABS brake system which is always enabled.
• COMPETITIVE DRIVING - In this mode, Active Handling and ABS are both enabled, but traction control is shut off.
The "OFF" and "COMPETITIVE DRIVING" modes are important features on a high-performance sports car like the Corvette. As mentioned earlier, skilled drivers may find that some wheelspin and oversteer can be beneficial to their lap times in competitive events, and the Corvette system allows them to operate the car in this fashion when appropriate. Chevrolet recommends against selecting these modes for street use.
