[Z06] Rear tow hook
Old May 16, 2008 | 04:40 PM
Bristol's Avatar
Bristol
Default Rear tow hook
Does anybody know the length of the exhaust 13mm bolts on the exhaust bracket. I am putting a rear tow hook on and seems that I will need a longer bolt then is on the C6 Z06. So before I start the job I want to have the proper size and grade 13 mm bolts.
Any body know??
Old May 17, 2008 | 05:54 AM
BlackZ06's Avatar
BlackZ06
You should post this in the C6 Z06 forum .....
If you are installing a Bray Krause hook ... just follow their instructions ... they make excellent products ....
http://www.bkauto.com
Old May 17, 2008 | 07:04 AM
AU N EGL's Avatar
AU N EGL
Any body know??
You need longer bolts. I tried to put my rear tow hook on with stock bolts and they were too short.
I think the bolts were at least 15 mm - I used 20 mm to make sure they fit.
Old May 17, 2008 | 10:44 AM
BlackZ06's Avatar
BlackZ06
AU_N_EGL .....
Where is your hook from ... I like the way that one is mounted ....
Thank you,
Old May 17, 2008 | 10:56 PM
Bristol's Avatar
Bristol
And the worst istructions. "take it apart and put in on"
they have useless instructions.
Old May 17, 2008 | 11:06 PM
Cornfed's Avatar
Cornfed
Looks like the Phoenix Performance in PA. Thats what I have. My exhaust doesnt use the factory exhaust brackets so they work just fine for me.
Old May 18, 2008 | 07:35 AM
AU N EGL's Avatar
AU N EGL
AU_N_EGL .....
Thank you,
Yes Phoenix Performance
http://forums.corvetteforum.com/show....php?t=2014583
To Rear tow hook
