What oil pressure?
Old May 17, 2008 | 01:06 PM
LMB-Z's Avatar
LMB-Z
Default What oil pressure?
I have a stupid question...what is the normal for oil pressure? My DIC says 130, but the gauge only goes to 80 psi. Is this normal? Thanks in advance.
Old May 17, 2008 | 01:16 PM
Whiteonrice's Avatar
Whiteonrice
No it's not normal. You probably need a new oil pressure sending unit. Pretty common problem.
Rick
Old May 17, 2008 | 01:51 PM
DeeGee's Avatar
DeeGee
Its a common problem
Take a look at this thread and you'll find what you need to fix it. Worth runiing through all the thread.
http://forums.corvetteforum.com/show....php?t=1588172
Old May 17, 2008 | 03:05 PM
LMB-Z's Avatar
LMB-Z
Is the car still driveable or do I need to replace the sensor before driving?
Old May 17, 2008 | 04:05 PM
c5streak's Avatar
c5streak
It's driveable, won't hurt a thing. But, you need to get it fixed so you can keep an eye on the beast!
Old May 17, 2008 | 04:36 PM
roscoe118's Avatar
roscoe118
I can't add anything to the previous posts. But I will say that when it comes to oil, or more specifically oil pressure, there are no "stupid questions".
Good luck with the fix.
roscoe
To What oil pressure?
