Tire pressure sensor relocation?
Old May 17, 2008 | 04:31 PM
flaagan's Avatar
flaagan
CF "Young" Senior Member
St. Jude Donor '12
Default Tire pressure sensor relocation?
Quick question I have about the TPS on my '01 C5.
I had new tires put on a week ago, and just now noticed that the front wheels are on opposite sides. One wheel had a minor nick in it that I realized was on the wrong side (driver instead instead of passenger).
Do I need to go back to the tire shop and get them to swap wheels / tires, or is this not an issue and the system should know which sensor is at which wheel?
I searched around a bit already and haven't come across any posts about this; sorry if it's already been stated somewhere and I missed it.
Old May 17, 2008 | 04:36 PM
HawnHog's Avatar
HawnHog
I'm certainly no expert, but a simple "reprogram" will do it. A magnet around the stem and going thru you DIC or a hand held unit that most tire shops carry should do it....
Old May 17, 2008 | 04:38 PM
garage-ghost's Avatar
garage-ghost
The sensors will have to be reprogrammed or the wheels put back where they were. The car doesn't know where the wheels are unless you tell it.
Old May 17, 2008 | 04:40 PM
c5streak's Avatar
c5streak
https://www.corvetteforum.com/techti...D=77&TopicID=1
You can use a magnet like from an old speaker or something, instead of the special tool.
Old May 17, 2008 | 05:43 PM
flaagan's Avatar
flaagan
St. Jude Donor '12
Perfect, thanks for the info guys! The forum comes through again!
Old May 18, 2008 | 12:22 AM
GMANS C5's Avatar
GMANS C5
Old May 18, 2008 | 01:18 AM
dobewillie's Avatar
dobewillie
good post and info
To Tire pressure sensor relocation?
