Pull Key Wait 10 Sec ???????????
May 17, 2008 | 11:08 PM
Has Anyone Ever Seen This Pop Up On The Dic??? It Happened To Me Today And The Car Stalled Until I Followed It's Command.
May 17, 2008 | 11:18 PM
Check out the Column Lock sticky thread in Tech
May 17, 2008 | 11:19 PM
May 17, 2008 | 11:26 PM
I saw it once and only once. it was several months ago and no issues since. I sure hope I don't have to run into that problem.
May 17, 2008 | 11:32 PM
May 17, 2008 | 11:34 PM
St. Jude Donor '08
Get a CLB and install it before you get stranded!
May 18, 2008 | 03:12 AM
Quote:
Originally Posted by
tbar1963
Fit a CLB and your worries wil be over
May 18, 2008 | 05:02 PM
DeeGee
What he said!!
May 18, 2008 | 05:13 PM
Does not always mean you have a crisis with the column lock. I had that show up on my 97 several times over the 6 years I owned it and never had a column lock problem. One time it occurred as I was waiting for a traffic light to change after the car had been driven for an hour or so.
Bill
May 18, 2008 | 08:09 PM
I used to get this occasionally, seemed to happen when I had a low battery. Once I changed the column lock out hasn't happened since.
May 18, 2008 | 09:07 PM
Happen one time after an oil change 98 C5 not bad for 10 years old.
May 18, 2008 | 09:17 PM
Get yourself a Column Lock Bypass and forget about getting stranded due to the column lock issue.
May 18, 2008 | 10:07 PM
I have had it a few times. It only appears after I start the car and then turn it back off quickly for some reason and then start it back up quickly. I do as it says and have never had a problem.
May 18, 2008 | 10:08 PM
JDs00PewterCoupe
May 18, 2008 | 10:20 PM
This message can mean just that your key's resistor pellet may need cleaned. Clean it with alcohol. If this doesn't work, try another key.
To be a column lock problem you must get the "service column lock" message.
May 18, 2008 | 10:31 PM
I seen it for the first time every on my 98 I thought it was because I was Auto-crossing and turning the wheel when I was starting the car.
May 19, 2008 | 08:38 AM
tbar1963
Putting a CLB on the early years can actually make this symptom appear, but as others have indicated, this message does not mean you have the dreaded column lock problem...
May 19, 2008 | 09:07 AM
I've only seen it once since i've owned the car. If it happens to me again, i'll install the CLB. Thanks guys
May 19, 2008 | 10:01 AM
Are you sure you don't already have one installed? If you try to turn the steering wheel with the key out, does the wheel turn?
May 19, 2008 | 01:36 PM
poolboy
Unfortunately, I am one of the early C5 owners that the CLB bypass is of no help, it actually introduced said problem.
