Sorry this is a silly question.
Old May 21, 2008 | 09:28 PM
4deatr's Avatar
4deatr
Default Sorry this is a silly question.
Can you reuse the oil from the PCV Oil Catch Cans? I get alot of oil in mine and dont know if I can reuse it.
Old May 21, 2008 | 09:31 PM
dobewillie's Avatar
dobewillie
I suppose you can but I wouldn't just on general principles
Old May 21, 2008 | 10:22 PM
CCA Corvette Parts's Avatar
CCA Corvette Parts
Premium Supporting Vendor
St. Jude Donor '07-'08,-'13-'14, '16-'17
We advise no when asked...
Peace
Chip
__________________
..................Click for
Old May 21, 2008 | 10:27 PM
bugsas99's Avatar
bugsas99
you have got to be kidding. why would you want to?? you drive a corvette and can't afford some oil??
Old May 21, 2008 | 10:35 PM
MagRedConv's Avatar
MagRedConv
Originally Posted by 4deatr
Can you reuse the oil PCV Oil Catch Cans? I get alot of oil in mine and dont know if I can reuse it.
I've read this question a few times and quite frankly it reads to me as if "can the catch can be re-used?" If it read "Can you reuse the oil from the PCV Oil Catch Cans?" it would be an easy answer.
Or maybe I'm just having a hard time over here!
Old May 21, 2008 | 11:45 PM
jrose7004's Avatar
jrose7004
I wouldn't.
Old May 21, 2008 | 11:48 PM
itzza427's Avatar
itzza427
You're right it is kind of a silly question!! I suppose you could,,but why would you want to!!
Old May 21, 2008 | 11:49 PM
WildTurkey's Avatar
WildTurkey
Old May 22, 2008 | 12:07 AM
DeeGee's Avatar
DeeGee
Probably not smart to put used oil back in.
Save a nickel and risk a $
Old May 22, 2008 | 07:46 AM
4deatr's Avatar
4deatr
The oil in the car is no more used then the oil that is in the PVC Catch Cans. I never have put it back in the car and I never intended to reuse it. I use a Amsoil and my low oil light came on and I only had one quart left. Sometimes it takes my Amsiol dealer to get me a new one.
Old May 22, 2008 | 08:36 AM
killain's Avatar
killain
Oldtimer
I'll just echo the other posts except this is the place to ask questions, sometimes you may feel silly in asking, but go ahead and ask. The oil in your car needs to be as clean as possible. The oil in your catch can has beed all through the engine and the PVC system and is not only a small amount but it's not all that clean. So in short don't use it. Go to Walmart and buy yourself some extra quarts of oil for the times you need to top off the engine. I'd look into the reason your getting what I assume to be a lot of oil in the catch can. Normally you should be getting a very little in the can. If this is not the case I suppose your getting a lot of blow-by and that could indicate another source. good luck!
Old May 22, 2008 | 09:12 AM
vetter79's Avatar
vetter79
NO NO NO NO!!! DON'T!! Why put used oil & contaminants in your car?
Old May 23, 2008 | 12:08 AM
Got to agree - I wouldn't put it back in the car.
Old May 23, 2008 | 12:29 AM
yaknow's Avatar
yaknow
I wouldn't use it in my lawnmower, let alone in my vette.
Old May 23, 2008 | 12:36 AM
C66 Racing's Avatar
C66 Racing
I wouldn't reuse it in mine... and FYI, for those that weren't aware of it, AMSOIL can be ordered online at dealer wholesale prices via the AMSOIL Preferred Customer Program. Normal shipping time is about 2 business days.
__________________
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
Old May 23, 2008 | 07:31 AM
7thson's Avatar
7thson
I'm sitting here trying to figure out why the oil couldn't be re-used. It's in the same closed environment as the rest of your oil so I don't see why not.
Old May 23, 2008 | 07:38 AM
DefenderC5's Avatar
DefenderC5
Meh, I dunno...I'd probably use it in my lawnmower
Old May 23, 2008 | 07:54 AM
WKMCD's Avatar
WKMCD
There are no silly questions - only silly people that ask them.
By the time the oil condenses in the catch can its probably going to have a fairly high content of water...Oil's cheap (by the quart).
To Sorry this is a silly question.
