A4 vs. MN6
a high rear end gear ratio puts your engine at 1200 RPM at 55 mph.
a medium rear end gear ratio puts your engine at 1800 RPM at 55 mph.
a low rear end gear ratio puts your engine at 2700 RPM at 55 mph.
with a lower geared car, you will get there faster, but the high geared car will pass you in top end.
This is the reason you don't see 1/8th mile drag cars running in the quarter. They just don't have the gear for it. They are built to run up to the 1/8th, but after that its just passing time till they get to the quarter. and Vise Versa, you don't see 1/4th mile cars running in the 1/8th cause the 1/8th mile cars will kick their *ss.
If you go with a lower gear in the rear end it will pull harder and be quicker, but the RPM's will go up at top speed and so will your gas bill....
As far as the difference between the two, I like my manual, but the factory gears in my buddies auto seem to pull harder.
Another friend of mine ran his 5.80 1/8th mile car in the 1/4th for the speedvision show Pass Time, and when he went through the traps he floated the valves because he was beyond redline... Results of running a 1/8th mile car in the 1/4...
At least he still ran a 9.60!
X2Most logical answer to this "debate" that I have read here
MN6 - 4.7 sec
A4(3.15) - 4.9
A4(2.73) - 5.1
As you can see the MN6 is generally tested as the fastest. Partly because of the gearing advantage and partly because in the right hands and manual can snick off a quicker more power efficient shift.
However, in the wrong hands a manual can be considerably slower.
I DO know that with the a-4 and 3:42's you actually have a better gear ratio than a Zo6 through first gear,then it may fall off a bit
As previous advice stated, personal preference and how you plan to use your car is the way to go. I know that the magazine times 0-60 the manual is almost always faster, but if the driver blows a shift those times don't make it to press
Take engine RPM, divide by transmission gear ratio, then divide by the final drive ratio, and you have the wheel RPM.
Don't get too much wrapped up in bench racing. Get the trans best suited to how you drive, or want to drive. If you love to shift and won't be doing high HP drag racing, then MN6 is for you. If you get bored with shifting, then A4 is the way to go. After that, you can modify either to fine tune it to you.
But, if you just want to bench race, its a never ending debate because there are so many variables. LOL...
You have to multiply the read end ratio by the transmission ratio to get the true gear ratio.
Here are the transmission ratios:
4 Speed Auto (3.15:1 or 2.73:1 axle ratios)
1st, 3.06
2nd, 1.63
3rd, 1
4th, 0.70
6 Speed Manual (3.42:1, axle ratio)
1st, 2.66
2nd, 1.78
3rd, 1.30
4th, 1
5th, 0.74
6th, 0.50
1st gear in a manual would be 2.66 X 3.42= 9.0972:1
1st gear in an automatic would be 8.3538:1 (2.73:1) or 9.639:1 (3.15:1).
So....
4 Speed Auto (2.73:1)
1st, 8.35
2nd, 4.45
3rd, 2.73
4th, 1.91
4 Speed Auto (3.15:1)
1st, 9.64
2nd, 5.13
3rd, 3.15
4th, 2.21
1st, 9.10
2nd, 6.09
3rd, 4.45
4th, 3.42
5th, 2.53
6th, 1.71
An A4 with 3.42:1 would be:
1st, 10.47
2nd, 5.57
3rd, 3.42
4th, 2.39
http://www.idavette.net/facts/c5specs/index.htm
http://www.chevyhiperformance.com/te...ing/index.html
Why would this thread get locked?
Anywho, I chose the right transmission for me guys, I was just curious about the acceleration times and if they were that much different. Lot's of people ask me about it, so I figured I actually got a car that was much slower due to a different transmission. Thanks for all the technical FACTs. Love those types of responses better than the normal stuff that finds its way into threads sometimes. You guys kick ****!
-Alex
While technically correct, the A4 has lower gearing in the transmission, so overall 1st gear ratio is approx the same.
2.66x3.42=9.097 (manual)
3.06x2.73=8.354 (2.73 A4)
3.06x3.15=9.639 (3.15 A4)
When you get to 1:1 tranny ratio, the car with the lower gear will still pull harder, but I think as a general rule, you should always consider the overall final drive ratio.
**Edit..........71vetteinva's post was spot on. I should have read the whole thread before posting mine.
