help! c5 falling apart.pics
Old May 22, 2008 | 08:20 PM
Blackpixi7's Avatar
Blackpixi7
Default help! c5 falling apart.pics
Ok, not literally, but my C5 needs some TLC. For starters, the molding that goes around the bottom of the windshield is dry rotted and falling off the car. Can anyone direct me to a place where I can pickup a new one? And, yesterday, I removed my side molding, but the glue is left over. I'm afraid that if I try to remove it with alcohol, the paper towels will scratch the **** out of my door and leave me tons of swirl marks. Is this something a professional detailer should be able to remove? Can anyone recommend one in the NJ area? And lastly, my HUD as seen in the pics, has a cracked/rotted piece on the front of it, any idea on what it is and how I can replace it? I'm guessing it's just because of its age and direct contact with the sun over the years. Also, does anyone know where I can get the front license plate cover surround that surrounds the front plate with a nice clean factory painted border? I need one in black, and mid america says they're all on backorder...
Old May 22, 2008 | 08:34 PM
stingraymyway's Avatar
stingraymyway
From: Out of Site...Out of Mind. Corvette: anything else is just transportation.
St. Jude Donor '09 thru '20
Use a product called GOO GONE. It will safely remove the leftover glue without any trama.
Old May 22, 2008 | 08:41 PM
VinnyT's Avatar
VinnyT
Do NOT use Goo Gone!!! It will remove clear coat. It will be gradual, but will thin it out and if you use enough of it, remove the clearcoat.
I recommend WD-40. It is much safer on the paint.
Old May 22, 2008 | 09:00 PM
71vetteinva's Avatar
71vetteinva
Is your weatherstripping rotting or just pulling away from the windshield? My seal was fine, but it was pulling away from the window. I got some black silicone adhesive from that auto parts store and simply glued mine back into position.
Old May 22, 2008 | 09:45 PM
cupidsrevenge's Avatar
cupidsrevenge
Dude! Good luck with the glue, should find a place to park car that is under some sort of roof. Always garage keep a car you want to last for a while without any of that dry rot going on!!
Old May 22, 2008 | 09:48 PM
Blackpixi7's Avatar
Blackpixi7
thanks, but I gotta work with what I got, and I don't have a garage unfortunately, she sleeps outside 24/7. I'll try the WD-40 and see how it works, and the windshield trim is rotted out
Old May 22, 2008 | 09:55 PM
sneakelman's Avatar
sneakelman
St. Jude Donor '08-'09
Check with Gene Culley for the parts. If anybody has it, he will.
Old May 23, 2008 | 12:10 AM
clayton1's Avatar
clayton1
Banned Scam/Spammer
Mines doing the same thing shown in your first picture.
Old May 23, 2008 | 08:39 AM
chevy406's Avatar
chevy406
Originally Posted by 71vetteinva
... My seal was fine, but it was pulling away from the window. I got some black silicone adhesive from that auto parts store and simply glued mine back into position.
Good idea - I'll try that on mine this weekend.
Old May 23, 2008 | 11:12 AM
candacedianne's Avatar
candacedianne
Try: http://www.tld-corvette.com/ for parts. they are in GA and I have purchased many items from them at their store. Good luck!
Old May 23, 2008 | 11:39 AM
RedSoxFan's Avatar
RedSoxFan
I wouldn't use paper towels to remove the glue, they can be coarse and scratch the clearcoat. Use a soft cloth.
Old May 23, 2008 | 01:31 PM
stingraymyway
Look at where the adhesive is on the pics.
Didn't know the windshield had clearcoat on it.
Old May 23, 2008 | 01:54 PM
doje's Avatar
doje
St. Jude 15 Year Donor
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20
The clearcoat in question is for the glue left by the body side mouldings. Read the whole thread.
Old May 25, 2008 | 09:57 PM
stingraymyway
An Air sander with 80 grit will take care of the side molding glue.....
Just let 'er rip!!
Old May 26, 2008 | 12:08 AM
TexasMadMan's Avatar
TexasMadMan
Use what the pros use. 3M adhesive remover for the BSM issue.
Old May 26, 2008 | 09:31 PM
EDenney's Avatar
EDenney
The license plate trim you're talking about is a "Smoothie". They really enhance the look if you have to put a front license plate on your C5. You can buy them in all major factory colors from Corvette Central, just search for 'smoothie' on their site. I know you can buy them elsewhere too, but the pricing for these is usually pretty consistent.
To help! c5 falling apart.pics
