Leaking convertible top?
Old May 24, 2008 | 09:59 AM
Mxzx's Avatar
Mxzx
Default Leaking convertible top?
Does anyone else have one that leaks above the windows? Mine seems to do it where the frame hinges for opening. The weatherstripping looks to be in good shape too??
Thoughts?
Old May 24, 2008 | 02:58 PM
Sully C5's Avatar
Sully C5
Cruise-In II Veteran
I had the same problem. It needs adjusting. Dealer did mine.
Old May 25, 2008 | 08:24 PM
BATM4N's Avatar
BATM4N
You need some adjustment and you can also do a "window tip" where you adjust the window to tip in more so it touches the weather stripping more than it does now.
To Leaking convertible top?
