Garage Widths
Old May 25, 2008 | 01:29 PM
KenHorse's Avatar
KenHorse
From: I live my life by 2 rules. 1) Never share everything you know. 2)
St. Jude Donor '11-'12-'13, '16-'17-'18
Old May 25, 2008 | 02:09 PM
MIKE-C5's Avatar
MIKE-C5
St. Jude Donor '05-'06-'08
Originally Posted by vettesplus
45 ft wide and 52 ft deep works ok for me......
sweet
Old May 25, 2008 | 06:15 PM
moserbe's Avatar
moserbe
Mine is 24'x32' and I wish that it were deeper. I built a 12'x20' just for the wife's C4 and that I would now have made a couple of feet wider.
Old May 25, 2008 | 06:53 PM
71vetteinva's Avatar
71vetteinva
My garage is 131.5 inches wide. That's just short of 11 feet. I have no problem getting in and out of the C5. I've never had a problem with the passenger side, either. I just have to take a little care when exiting. I could put a pad on each wall, but it's really not necessary.
That said, I don't think I'd let a child open either door, since they may not have the dexterity or will to prevent an accident.
Old May 25, 2008 | 06:55 PM
hotwheels57's Avatar
hotwheels57
Mine is 33' deep x 55' wide x 12' ceiling height, attached...they're never big enough!
Old May 25, 2008 | 07:24 PM
luk2004's Avatar
luk2004
5th Gear
All these big garages make me jealous. I just moved into a new place with a garage for a change and its only 130" wide inside. Just barely enough room maybe. I want a Vette so bad!!
A better question to help me is how much width do you need with only one door partially open (first notch)?
Old May 25, 2008 | 08:45 PM
71vetteinva
Hmmm...that means you'll have 0.75 inches less on each side than I do. You should still be fine. You'll just need to hold the door a little when you enter and exit. Not a big deal.
There will be a few limitations. The car door obviously won't stay open on it's own, nor will you be able to vacuum the interior without risk of damage. Still, I've never had a problem waxing the car or even doing some minor mods in that space.
The actual opening of my garage door is 105 inches.
I think the car is going to fit. Post photos when you buy it!
Old May 25, 2008 | 08:53 PM
ROJ#79's Avatar
ROJ#79
In central NY you are lucky to find a garage that is more than 20X20.
A lot of them are 19X20 with one corner angled off where entrance comes into the home.
No t large in my standards but, that's the way they build them. (CHEAP)
Old May 25, 2008 | 10:07 PM
The NNIAL8R's Avatar
The NNIAL8R
St. Jude Donor '11,'13
"I voluntarily took 60 days off from OT"
Time to fill that sucker up!!!!.......I have enough vehicles to fill one like that, but if I built it Id have to sell some of the vehicles to afford it!!!!...Guess I'll hafta keep letting our DDs sit outside
Old May 25, 2008 | 10:44 PM
The NNIAL8R
[QUOTE=71vetteinva;1565615544]Hmmm...that means you'll have 0.75 inches less on each side than I do. You should still be fine. You'll just need to hold the door a little when you enter and exit. Not a big deal.
DANG!!!!....It's a good thing we're talking about GARAGES here!!!
Old May 25, 2008 | 11:18 PM
34RedRage's Avatar
34RedRage
Default garage
my avatar shows what fills it up at night.....
Old May 25, 2008 | 11:34 PM
The NNIAL8R
I count three.....Looks like that sucker could handle all eight of my rides....BTW, does your lifted truck fit in it??
Old May 25, 2008 | 11:40 PM
  #33
dachevy's Avatar
dachevy
Originally Posted by kww
My garage is a pretty standard 24x24. Enough for the cars, lift and scoot along with work bench and side cabinets and heat/ac.
do you like yellow corvettes', nice
Old May 25, 2008 | 11:55 PM
  #34
The NNIAL8R
One of our club members has a supercharged 04 yellow Z06...personalized tags...FASTAXI
Old May 26, 2008 | 07:30 AM
  #35
kww's Avatar
kww
The C5 was my first yellow car-ever. They're kinda of growing on me-the 74 is an L82/M21. The "ford" I always thought was a quick car-425hp but the C5 would definitley blow it in the weeds. I like his plate-I got stuck with the govenor's old plate 00001. But to answer the original question 24x24 will give you plenty of room to get in and out of.
Old May 26, 2008 | 11:56 AM
  #36
34RedRage's Avatar
34RedRage
sorry if my pockets are not as deep as yours!!!!!
yes with room to spare!!!!
Old May 26, 2008 | 12:11 PM
  #37
tellefan's Avatar
tellefan
Now that's what I call a garage My lot size and building codes restricted me to 24x27 but it's better than nothing. David
To Garage Widths
Old May 26, 2008 | 12:42 PM
  #38
The NNIAL8R
Sure they are...you just spent your $$ on a house and garage instead
How tall are your garage doors??
Old May 26, 2008 | 01:11 PM
  #39
34RedRage's Avatar
34RedRage
i built my own house and garage so not alot of $$ in it.
you must be playing on the dark side to be able to afford all your toys on a cops wages... my doors are 8 ft tall
Old May 26, 2008 | 01:23 PM
  #40
The NNIAL8R
Not a lot in it??....My brother-in-law is a custom home builder...he does a lot of work with brick....There's a fortune there!!!
and "Dark side" you say???..HARDLY...Ive worked TWO jobs for the past 20+ years....My wife works too....as far as my toys....theyre all paid for except the SSR and C6 Z-06....and lets not forget Im probably 20 years older than you are and no kids at home...and as far as my house...
