Which do you guys trust
Old May 25, 2008 | 01:09 PM
C5RClone's Avatar
C5RClone
Default Which do you guys trust
I get quite markedly different tire pressure readings from a digital gauge to my onboard readout. I'm going with the gauge, my car is eight years old and it should be more accurate at the wheel, should it not?
Old May 25, 2008 | 01:19 PM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
I use a nice round guage I bought and it is spot on, I also find that my DIC is spot on also. I myself never did like the digital gauges.
Old May 25, 2008 | 01:31 PM
uniqvett's Avatar
uniqvett
I like to use a tire guage in the morning when the tires are cold.
Old May 25, 2008 | 02:08 PM
steve8's Avatar
steve8
I'd try a new gauge.
Old May 25, 2008 | 02:09 PM
CamachoSF's Avatar
CamachoSF
The DIC works dead on for me
Old May 25, 2008 | 02:24 PM
Dominic Toretto's Avatar
Dominic Toretto
DIC is awesome, just make sure you TPS are working good also. Don't know about when they start to fail, but since I will be getting new wheels and tires this year may as well throw some of those on the "To Buy List" also.
-Alex
Old May 25, 2008 | 02:38 PM
JimZRyd's Avatar
JimZRyd
St. Jude Donor '12
No difference here between my hand held gauge and my dic.
Old May 25, 2008 | 04:09 PM
robsc501's Avatar
robsc501
Hi There
No difference here.
robsc501
Old May 25, 2008 | 06:02 PM
moserbe's Avatar
moserbe
My DIC is right on with my old and cheap tire gauge.
Old May 25, 2008 | 06:09 PM
jrose7004's Avatar
jrose7004
My DIC is always right on it!
Old May 25, 2008 | 06:12 PM
Mr.Bill's Avatar
Mr.Bill
My DIC works 100%.
Old May 25, 2008 | 09:13 PM
GrayC5's Avatar
GrayC5
Get a good dial type analog gauge and dump the digital. I too have not found the digital gauges I've had in the past to be all that accurate.
Of the gauges I now own, one of my favorites and one that I carry in the C5 all the time is an Accu-Gage H60X. The hose type gauges are great for hard to reach valve stems. You should be able to find one of these for around $20 more or less and I've found them to be very accurate for the price. Mine is always right on with the DIC. Too, I've compared it a number of times with a friends glycerin filled professional analog gauge for which he paid over $200. My Accu-Gage has been right on with his every time.
You can read more about the Accu-Gage dial type gauges at the following link:
Accu-Gage® Dial Gauges
HTH and Good Luck!
Old May 25, 2008 | 10:15 PM
Keppler's Avatar
Keppler
St. Jude Donor '25-'26
When I replaced tires last fall I also replaced the tire pressure sensors. Bought the tires online and had a Goodyear store mount the tires. When I picked up the car the service tech said he also calibrated the tire pressure sensors. I did not know this was possible. I have never read a post that has mentioned calibrating the TPS. You may want to call a Goodyear store and ask if they perform this service.
Old May 26, 2008 | 03:31 AM
ljthe2nd's Avatar
ljthe2nd
Did they charge you for this service? There is no such thing as calibrating the tire pressure sensors.
Old May 26, 2008 | 08:02 AM
Mr.Bill's Avatar
Mr.Bill
Old May 26, 2008 | 08:04 AM
silversport's Avatar
silversport
well...that answers the question for me...need a new gauge as I too get different readings from the DIC and the digital gauge...
Bill
Old May 26, 2008 | 08:28 AM
rws.1's Avatar
rws.1
I use a Moroso analog gauge. it usually reads about 2 pounds higher than the DIC.
To Which do you guys trust
