Front Re Bar
Old May 26, 2008 | 09:09 PM
Nashville Natureboy's Avatar
Nashville Natureboy
Default Front Re Bar
Beside being in the front and being a re bar, where would I find my build sheet. I want to find out what suspensionI have so I can lower my car.
Old May 26, 2008 | 09:17 PM
c5streak's Avatar
c5streak
Should be a RPO list on the bottom of your left storage comp cover. It will list the RPO for your suspension like Z51, F45, etc. If you don't have the RPO sheet, you can order a build sheet from the Museum.
Old May 26, 2008 | 11:04 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
could be in your glove box too, depending on what year your car is.
Old May 27, 2008 | 07:58 AM
Nashville Natureboy
On the left storage comparment cover in the truck area is a sticker that reads Service Parts Identicication. There are several numbers listed on it, but not Z51 or F45. BTW, my car is a 98 vert. The question about the front rebar is from the Secrets of C5's list that was going around. It said the build sheet could be found there.
Old May 27, 2008 | 08:05 AM
red 1's Avatar
red 1
The sticker in the storage area should say FE1 for base suspension or FE3 for Z51 suspension.
Old May 27, 2008 | 08:43 AM
Nashville Natureboy
OIC It says FE1 which is F45. Right? Thanks Red 1!
Old May 27, 2008 | 08:53 AM
D Baize's Avatar
D Baize
FE1 is the base suspension, F45 is the selective suspension, and, Z51 is the optional sports suspension. As listed before, there is a sticker on the inside glove box door which lists all the build codes on your car. Dave
Old May 27, 2008 | 09:21 AM
jrose7004's Avatar
jrose7004
Order a build sheet www.corvettemuseum.com
To Front Re Bar
