C5 headlamp motor casing assembly
Old May 27, 2008 | 04:11 PM
C5 fury's Avatar
C5 fury
Default C5 headlamp motor casing assembly
Hi- I've already installed the brass gear on the left headlamp 1-2 years ago, but the glue has now failed. The gear housing edges are getting rough and the likelyhood of a re-glue lasting is not promising. After searching the forum, one member suggested a "t-brace" which I imagine will hold the gear casing together. I can not find any additional info on this fix. Please let me know what my options are (I was quoted $317 for the assembly at the dealers).
Thanks for the help! -Mark
Old May 27, 2008 | 04:17 PM
DeeGee's Avatar
DeeGee
E Mail Rodney Dickman who sells the brass gears. he'll send you the T brace for a few $$
Old May 27, 2008 | 04:21 PM
02MillenniumVette's Avatar
02MillenniumVette
Dont go to the dealership, they are just going to give you another one with the nylon gear in it. The t-brace is what you need. The brass gear kit that I bought from Corvette Central came with it. If you cant find a t-brace then you can always use small screws and screw the cap on. Just make sure the screws dont interfere with the gear. This is what the t-brace looks like in the pic below.
Old May 27, 2008 | 04:22 PM
rws.1's Avatar
rws.1
PM sent
C5 fury's Avatar
C5 fury
Thanks DeeGee, I'll give it a try. -Mark
To C5 headlamp motor casing assembly
