strange problem.. stumbling?
Old May 29, 2008 | 12:28 PM
ravn's Avatar
ravn
Default strange problem.. stumbling?
I've been encountering a fairly weird problem for a while now, and havent been able to sort it out, so I figured I'd check with you guys.
If I am on the highway and in 3rd gear (automatic) and get on the gas - just a little bit, not enough to force a downshift but enough to start to raise up the RPMs enough that the car would consider shifting to 4th - the car does something that I can only describe as "stumbling" - it shudders/bucks, coming from the back end (or rather, it FEELS like it is coming from the back end). If I get off the gas, it stops, and if I get on the gas more it stops. No error codes thrown.
Any thoughts?
Car is a '99 A4.
Old May 29, 2008 | 12:34 PM
RON NARDONE's Avatar
RON NARDONE
when you are in o-drive and letting the car shift normally do you get that "shudder and bucking" when the car shifts??????also how many miles on the car
Old May 29, 2008 | 01:09 PM
ravn's Avatar
ravn
I'm sorry, that is in o-drive, not when manually shifting it.
I'm just used to the RPM ranges at speeds, so I generally know which gear its in. It will also do it from 4th gear, if I just gently get on the gas.
roughly 76-77k miles.
Old May 29, 2008 | 03:19 PM
BlueDragon's Avatar
BlueDragon
I have had this problem when a plug or plug wire goes bad. It didn't throw a code right away, but after a few times it did finally throw a misfire code.
Check your plugs and wires. Have you changed them recently?
I once bought a el-cheap-o set of wires and it did exactly what you are describing.
Drop to a lower gear, say second and try the same senario. Run along at a low speed, lug it if you have to and then slowly add some throttle. to get a misfire code you need to get the mixture rich enough to show up at the O2 sensors.
Old May 29, 2008 | 03:21 PM
ravn's Avatar
ravn
thanks for the tip!
they're probably overdue to be changed anyhow, so I'll just go ahead and do that
Old May 29, 2008 | 03:57 PM
Herringchoker's Avatar
Herringchoker
From: "Man been singin' the Blues, since he began to till the ground"...Vancouver, USA WA.
You also may want to try a can of "Sea-Foam" or "Berrymans-B12" next time you fuel up. JOE
Old May 29, 2008 | 05:34 PM
10U 99's Avatar
10U 99
St. Jude Donor '08-'09
time for plugs. and while you're there, wires
Old May 29, 2008 | 07:22 PM
Jet-Jock's Avatar
Jet-Jock
Have you peeked inside your throttle body?
Old May 29, 2008 | 07:31 PM
robsc501's Avatar
robsc501
Hi ravn,
I have had this same problem on many of my cars & other peoples cars.No codes shown in the DIC & the problem goes away when you let-off the gas pedal.You have clogged fuel filter buy the special tool & deplete the the pressure from the schrader valve on the fuel rail (drivers side).A/c delco p/n gf822 $86 A real pain in the butt to change on the a/tranny. Hardly any room to work.BTW: If you had a misfire you would have code p0300 displayed on the DIC.
robsc501
Old May 29, 2008 | 10:16 PM
Stock Man's Avatar
Stock Man
2015 C5 of Year Finalist
St. Jude Donor '05-'06-'07-'08-'09-'10
Try the seafoam trick as stated above. I did last year and have now put it through all our vehicles I am astonished at what a difference is has made.
Old May 29, 2008 | 11:30 PM
cupidsrevenge's Avatar
cupidsrevenge
I have a 99 A4 also and have had a similar problem. Do the RPM's increase roughly 200 to 300 when it "bucks", if so it may have to do with your torque converter. Also, if your battery had been disconnected at anytime, this will cause your computer to "re-learn" itself and your driving habits. I'd get it hooked up onto a computer for a street tune and that should be able to tell you exactly what the problem is and in most cases, the tuner can fix the problem...just my .02
Old May 29, 2008 | 11:34 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Take a look at the bottom of the PCV valve connection tube to the intake. It might have a hole in it which will cause your problems. It happened to mine so I know.
Old May 30, 2008 | 02:29 PM
ravn's Avatar
ravn
lots of good stuff, thanks guys.
I ordered some new plugs today - so will try that first (and prolly do some wires while I'm there.. I'm sure its overdue anyhow)
if that doesnt cut it, I'll give the seafoam a chance... if that doesnt do it, well, I'll try the other suggestions til it gets solved!
Old May 30, 2008 | 02:35 PM
Benpup's Avatar
Benpup
Cruise-In VI Veteran
Stupid question I guess.
I know if you Seafoam through the engine that you should change oil. Same thing apply with through the fuel system?
Old May 30, 2008 | 04:35 PM
The NNIAL8R's Avatar
The NNIAL8R
St. Jude Donor '11,'13
"I voluntarily took 60 days off from OT"
Change your plugs AND wires, replace your FUEL FILTER (not fun) and do a transmission fluid and filter change...I assure you with the miles you have on your car you NEED all this done!!!
Old May 30, 2008 | 04:51 PM
tellefan's Avatar
tellefan
Don't forget to clean the MAF sensor.
Old May 30, 2008 | 05:31 PM
ravn's Avatar
ravn
the MAF sensor was recently cleaned
and it appears the local jiffylube cant do the transmission on a corvette, joy, so I'll have to take it elsewhere for that
fuel filter... yes, I understand that's a pain.
hopefully do that when I swap out the suspension next week
To strange problem.. stumbling?
Old Jul 20, 2008 | 10:55 AM
1badf350's Avatar
1badf350
When you experience this 300-400 RPM slip while cruising does your cruise control go out?
I have been having this same issue for a while and I know when the car does this I cannot use cruise control.
Did you ever find your fix?
Old Jul 20, 2008 | 10:57 AM
ravn's Avatar
ravn
I rarely use the cruise control, so I'm afraid I dont know
I just (I know, I know, I'm terribly) replaced the plugs and the wires yesterday, and am about to go on a fairly long drive, so I will let you know later if that resolved the issue
Old Jul 20, 2008 | 11:00 AM
1badf350's Avatar
1badf350
OK ravn. Hey if it starts doing the same problem, try to set the cruise control. Let me know what happens.
Also I just noticed we're almost neigbors.
