How do you clean your engine bay?
Old May 29, 2008 | 04:38 PM
Hysteria's Avatar
Hysteria
Default How do you clean your engine bay?
I've done a search on "Engine detailing", "Cleaning Engine", and a few others to no avail. So if it's out there, I apologize.
What do you guys do to clean your engine bays? I used to (with my old cars) use Simple Green and wash it with a water hose. Two years ago I washed my Cobra and as I was driving, the alternator died, so now I'm leary about washing my engine bay. I don't have a leaf blower to blow dry my motor (I know most guys do this).
Any help would be appreciated.
Old May 29, 2008 | 04:51 PM
GOZ2FST's Avatar
GOZ2FST
Warm engine up a bit - NOT HOT - just very warm. Spray everything with Windex or the green stuff.
Close hood - wait about ten minutes.
Spray compartment with hose - make sure you're using a spray nozzle - again avoid the electronics as much as you can. Don't drench things - just spray as needed.
Then I pat dry with one of my "car towels".
Then spray everything with Armorall - this time avoid the belts as much as possible.
Close hood and wait another few minutes. Then I use paper towels to remove any excess Armorall.
This will give you a clean engine compartment that looks like you spent hours polishing!
Good luck.
Old May 29, 2008 | 05:10 PM
jrprich's Avatar
jrprich
Good luck.
I use 303 Aerospace Protectant rather than Armorall.
It lasts longer and does not attract dust and dirt.
http://303products.com/tech/index.cf...Product_ID=428
Old May 29, 2008 | 05:48 PM
Hysteria's Avatar
Hysteria
Good luck.
That's what I used to do, Thanks.
I used to use the Armour All afterwards as well. I'll try the 303 Aerospace since I just bought some a week ago.
Old May 29, 2008 | 06:23 PM
TheLegacy81's Avatar
TheLegacy81
With the hood seal installed, the engine bay isnt as dirty as it should. I wash my car every saturday. That also includes cleaning as much as I can in the engine bay. I get Simple Green, spray it on a car towel and I just rub it across all the surfaces I can in the engine bay. Then, I take a dry towel and repeat. Engine stays clean, I dont have to worry about drenching the electronics, its easy, and fast. The Hood seal definitely makes a huge difference.
Old May 29, 2008 | 09:53 PM
Jacks02's Avatar
Jacks02
FWIW: I parallel GOZ2FST, but use "Fantastic" for cleaning with great success. I've also found "SonofaGun" protectant to be superior to Armerall -- it lasts a lot longer and easier to use. I use it on all the rubber trim -- from weather strips to tire sidewalls. When applied to the black trim on top of the rear bumper on my C-1500 pickup, it stays black and fresh-looking for 6 months. Both are great products, and sell for much less than specialty automotive products.
Old May 29, 2008 | 09:58 PM
Hysteria's Avatar
Hysteria
Thank you for all of your ideas guys!
Old May 29, 2008 | 10:10 PM
GrayC5's Avatar
GrayC5
You can also find a lot more info on this subject in the Car Care Discussion section of the Forum. Too, several very knowledgeable people and a few professional detailers hang out in that section.
Good luck with the cleaning.
Old May 29, 2008 | 10:27 PM
ILM-Express's Avatar
ILM-Express
MFIC
I have not used any chemicals on mine for cleaning, I just blow the dust off with air blow gun.
And wipe everything down with a rag misted with armor all.
Old May 29, 2008 | 10:31 PM
VetteFTW's Avatar
VetteFTW
I spray on engine brite. Then I spray it off with the hose, then i start the car and let it get up to temperature. By that time, most of the water is evaporated. I get the puddles with a rag. Also, I use armour all too on some of the black parts. Make sure you cover your alternator, the battery area, and any other things that seem like they won't be water-friendly. The computer is under the battery area so be careful on that side. I spray from the passenger side. Don't douse it either, use light mist spray w/ water. It cleans up real nice, real fast.
Old May 29, 2008 | 10:50 PM
I've had mine since new and all I have used is an air compressor to blow the dust off, then use a moist Absorber to wipe things down. If I have a little grease to clean up, I just spray some Simple Green on a rag and wipe the mess up.
Old May 29, 2008 | 11:17 PM
BOTYNV1's Avatar
BOTYNV1
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19
Again, I have to stop this.
Old May 29, 2008 | 11:47 PM
GS Ron's Avatar
GS Ron
Bought mine new over 10 years ago and use Windex
and air compressor and after toweling off, I use an artist brush
to get the tight areas clean...................
Old May 30, 2008 | 01:21 AM
DeeGee's Avatar
DeeGee
I try to clean it regularly so it doesn't get to dirty to start with
I use Son of a Gun on all the plastic parts and a damp cloth on the metal parts.
To How do you clean your engine bay?
