Brakes dragging
In stop and go traffic it's much more noticeable, sometimes the brakes are dragging enough I can smell them heating up.
Twice I've had the car into the dealer, they can't find anything wrong. In an unrelated issue they replaced the ASB sensor, system ($1000).
Any ideas what the problem might be? I've always been impressed with the knowledge and expertise the members of this forum have.
I first noticed my gas mileage was taking a very noticeable downward spin. (I run all the time with my DIC set to show the instant fuel mileage).
Right after I bought the car, I put new pads on all four corners and resurfaced my rotors. This problem started about three weeks later.
To make a very long story short, I finally found out the douche bag I bought my car from (and the original owner) had put POWER STEERING FLUID in the brake fluid reservoir. It completely trashed my entire braking system. That meant new master cylinder, brake booster, ABS unit, brake lines, calipers, rotors, pads... everything. Final bill was just shy of $2k and that was buying the booster and master cylinder out of a rear-end crashed car.
I hope this isn't the problem you're having, but mine started exactly as you are describing.. brakes were dragging coming up to a stop light - finally got so bad the car would stop itself. Obviously I quit driving it and thats when I discovered what had happened. So check your brake fluid and make sure its CLEAR, not GREEN.
The other cause for this (and my original hope for my car) was just bad brake lines. I've heard plenty of rumors that the factory lines on C5 Z's aren't the greatest. You can pick up a new set of steel braided lines for around $150 shipped and install them yourself in less than an hour. While you've got the calipers off to swap out the lines, you might also check them - in my case, the pistons had gone to crap because of the power steering fluid and they weren't ever releasing completely, thus the drag. If the pistons in your calipers look fine, be thankful this isn't your problem!
And lastly, whatever you do, don't let this go on for too long without figuring out the problem or you'll completely trash your rotors. In my case since the problem was already as bad as it was when I got the car, it just gave me an excuse to upgrade to a nice slotted set.
Best of luck. Do keep us posted on what you find out.
Bill
Or the pistons are sticking in their bores. If you jack up your car, you should be able to spin each tire fairly easily. Of course make sure it is in neutral and the parking brake is off.
with Bill Dearborn I don't believe you have problem.You could check the fluid in the master cylinder.Put a drop light on the pass. side of the m/c & standing on the drivers side look at the fluid it should be nice & clear.Tip: do not remove the cap.(lets in moisture) Look for any leakage.If you should have fluid discoloration, bleed the entire brake system. The bleeding sequence is rr,lf,lr,rfAny abs codes being displayed?
robsc501
This forum is GREAT !!!
Unfortunately, I had the same problem with my car, only it was a brake shop which screwed up big time. Sticky caliper pin is a more likey problem though.
A few days ago I stopped at another dealer, they were smart enough to check for a Chevrolet Service Bulletin, hence the suggested repair of replacing the Vacuum Brake Booster.
I wish the first dealer had done that 19 months ago !!!!!!
I haven't done the repair yet.
Thanks for all the suggestions and advice.
