Corvette work order 1998
Old May 30, 2008 | 09:30 AM
oakvillec5's Avatar
oakvillec5
Default Corvette build order 1998
I've heard people talk about GM supplying the orginial build order for their Corvette. Is there a site or a phone number that anyone can pass along?
Thanks in advance
Last edited by oakvillec5; May 30, 2008 at 01:17 PM. Reason: used the wrong word in title
Old May 30, 2008 | 01:38 PM
Nashville Natureboy's Avatar
Nashville Natureboy
I think The Corvette Museum will make you one. I believe there is a $20charge. I found one in left storage comparment in trunk area on my 98Vert. Some folks say there is one in glove box, but there wasn't one on my car. The build sheet is hard to decipher if you don't know the codes, which I don't. Hope this helps.
Old May 30, 2008 | 01:44 PM
mqqn's Avatar
mqqn
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
St. Jude Donor '03-'04-'05-'06-'07-'11
Hi guys -
The factory build sheet is in the front frame cross-tube....
You can get a perfect re-print from the corvette museum -
https://store.corvettemuseum.com/ser...buildsheet.asp
The sticker on the inside of the glovebox door lists all the option codes that were installed on the car at the factory.
best regards -
mqqn
Old Jun 1, 2008 | 06:39 PM
oakvillec5's Avatar
oakvillec5
thanks, I have contacted the museum.
To Corvette work order 1998
