speedometer not working
Old Jun 1, 2008 | 07:28 AM
leo97's Avatar
leo97
Default speedometer not working
The wife and I went out to dinner last night, 22nd anniversary, wow, it was the perfect evening. The temp. was 78, had the top out, just enjoying the cruise, and then, bam-the corvette gremlins bit me in the a**. My speedometer just went to 0. All other gauges worked fine. I also noticed the instant mpgs stopped working as well as the trip odometer. Any ideas? By the time I got home, the speedometer started working again, but it's only a matter of time before the comes back!
Old Jun 1, 2008 | 10:57 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Check the connector on the transmission. I don't remember which one it is as there is more than one, but its probably loose or bad contacts. Someone else here will know if its the right or left side connector.
Old Jun 1, 2008 | 11:00 AM
oaks99's Avatar
oaks99
on the passenger side on top , and that will be the culprit
oak
Old Jun 1, 2008 | 11:51 AM
leo97's Avatar
leo97
Default speedometer
Thanks for the help, hopes it's a connector, and nothing more serious, like the bcm.
Old Jun 1, 2008 | 11:55 AM
The NNIAL8R's Avatar
The NNIAL8R
St. Jude Donor '11,'13
"I voluntarily took 60 days off from OT"
If it's not the connector it's possibly the Vehicle Speed Sensor that the connector attatches to....
Old Jun 1, 2008 | 12:02 PM
leo97's Avatar
leo97
Default speedometer
Is that going to require dropping the trans to replace?
Old Jun 1, 2008 | 01:35 PM
The NNIAL8R
No.......but if the connector isnt loose or disconnected I would have the car scanned before I spent $$ on a sensor..Most electrical parts cant be returned if they dont cure the problem....
Old Jun 1, 2008 | 04:42 PM
leo97's Avatar
leo97
Default speedometer
Thanks for the help, I'll check the plug, with any luck that will solve the problem.
To speedometer not working
