Window Tinting the Back window??
Old Jun 1, 2008 | 01:01 PM
Hysteria's Avatar
Hysteria
Default Window Tinting the Back window??
I've been kicking the idea around of tinting my windows. The one reason I'm unsure of doing it is because of the "Dot Matrix" on the top of the back window.
What do you guys do to make sure the tint doesn't peel or bubble?
Old Jun 1, 2008 | 01:04 PM
34RedRage's Avatar
34RedRage
i have my windows tinted at 20%. the dot matrix is almost unnoticeable. a good window tinter will do the job correctly....
Old Jun 1, 2008 | 01:45 PM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
Have a pro install it for you, It can be installed where it is hardly noticable.
Old Jun 1, 2008 | 01:46 PM
c5streak's Avatar
c5streak
It's all in the skill of the tinter. Mines been on "the dots" for 3 yrs now, and zero problems. Lots of guys put black vinyl on the dots. That works too, but it IS possible to get the tint to stick to the dots, my tint guy used sandpaper to lightly scuff the dots so the tin would stick.
Old Jun 1, 2008 | 01:53 PM
Hysteria's Avatar
Hysteria
Your car looks good!
I'll just go to a different shop to get them done. Thanks guys. It's just one of those things that I'd like to have done and done right the first time.
Do you guys all have a strip running accross the top of the front windsheild as well?
Old Jun 1, 2008 | 01:56 PM
CamachoSF's Avatar
CamachoSF
I had mine done at 20% at a local shop, he didnt do that great of a job, so when people ask, I just say," Oh corvettes are known for that." But on a serious note, i have some some good work around the dots.
Old Jun 1, 2008 | 02:22 PM
10U 99's Avatar
10U 99
St. Jude Donor '08-'09
mine was tinted when I purchased it. someone did an excellent job, no dots visible.
Old Jun 1, 2008 | 11:14 PM
coveett's Avatar
coveett
I have seen a lot of tint jobs at car shows and other events. Apparently, there are very few window tinters good enough to make all the dots disappear. Here is my solution. I had my window tinter stop the tint at the fourth defroster strip. After about a month of drying time I taped along the tint edge with ¼ inch masking tape. You want the tint to be thoroughly dry so it will not be lifted by the masking tape when you carefully remove it or you can freehand it. I then painted the untinted area with PermEnamel Ultra Black Satin paint for tile and glass. I got it from Hobby Lobby for under $ 5.00 for a 2 oz. bottle, which is more than enough. This type glass paint does not require heat curing. It takes 3 to 4 coats to eliminate all the brush strokes. Use soft brush like a makeup brush. The match is perfect. The dots are not visible and the edge of the original blackout from the factory is not visible either. Also, the blacked out area can not be seen from the drivers seat.
Old Jun 1, 2008 | 11:58 PM
jrose7004's Avatar
jrose7004
You can barely see it on mine.
Old Jun 2, 2008 | 05:19 PM
gray-c5's Avatar
gray-c5
St. Jude Donor '08
Default Careful
I had a tinter who claimed to be the best. He sanded my rear window. The job looked bad, big air buble in top center and you could see scrathes in the glass. I re[laced the rear window ($1,000).
Old Jun 2, 2008 | 05:59 PM
mhorton01's Avatar
mhorton01
Mine is 20% also, and the shop actually painted the dots in, which looks great. Of course it sux when it's your daily driver and you have to drive around for 3 days smelling paint and unable to roll down the window! I suppose I could have removed the top and left the windows up, but I'd rather smell paint then commit THAT sin.
Old Jun 2, 2008 | 11:37 PM
Mr.Bill's Avatar
Mr.Bill
I sure hope the tinter guy paid for your window, I have never heard of sanding the glass...
Old Jun 3, 2008 | 01:11 AM
DeeGee's Avatar
DeeGee
that you need a pro do the job
I had tint on ther Camaro which was factory fitted. It looked good for a few years but eventually delaminated at the complex curves and around the dot matrix. I took it off about two years ago so it lasted about 8 years although it was lifting for the last 3 years.
Old Jun 3, 2008 | 01:23 AM
Mr.TT's Avatar
Mr.TT
St. Jude Donor '10, '15-'16
My tint guy also did a great job. A good tinter can do the whole hatch without any bubbling on the dot matrix. Don't settle for less!
Old Jun 3, 2008 | 01:45 AM
The NNIAL8R's Avatar
The NNIAL8R
St. Jude Donor '11,'13
"I voluntarily took 60 days off from OT"
Limo tint on black looks GREAT!!!
Old Jun 3, 2008 | 02:02 AM
Mr.TT's Avatar
Mr.TT
I like your car NNIAL8R. I've been thinking about doing the red letters on the rear and the pass. airbag door. Ditto on the tint + black.
Old Jun 3, 2008 | 02:21 AM
The NNIAL8R
Thanks...your car is SWEET too!!!!!
Yes, I did the vinyl red airbag letters and the vinyl steering wheel decal too....I also like the taillight and license louvers.....I recently bought a 99 triple black Vert..
I just finished doing the airbag letters, steering wheel decal and same rear-end treatment (letters and louvers) so it matches my 99 Coupe....Also did drilled and slotted rotors on both cars, as well as Z-06 scoops and lowering them both...Went with limo tint on both cars all the way around...........I sold my Classic tip Corsas off the coupe and put on a set of Corsa Tigersharks...visible in this pic...
The vert has ProTip Corsas....
To Window Tinting the Back window??
Old Jun 3, 2008 | 08:36 AM
ronwc's Avatar
ronwc
Default tint
Had mine doen at Divine Sounds at DM and Waters in Tampa - very good job and reasonable - don't let anyone talk you into going darker than 20% if you want to see at night -
Old Jun 3, 2008 | 12:40 PM
superstreet's Avatar
superstreet
St. Jude Donor '10
The "black bumps" need to be very lightly rubbed over with a Scotch Brite pad. I stress very lightly or you will scratch the glass itself. Just enough to scratch the black dot matrix so the tint will have something to adhere to. Make sure the the window is washed thoroughly with a mix of water and liquid dishwasher detergent to get rid of all the debris.
You can stop the tint about 2 inches into the black lines and apply black vinyl tape the rest of the way up. Obviously you won't be able to see thru the tape, but it is a minimal width of tape.
Make sure you/they heat shrink the tint. No bubbles or "fingers" and in one sheet.
Old Jun 3, 2008 | 12:45 PM
ZO6 Lee's Avatar
ZO6 Lee
St. Jude Donor '08-'09-'10
My 'dotted area' is painted with the same paint that is around the edges of windows. It doesn't peel.
