Rear Wheels Spacers
Old Jun 1, 2008 | 08:58 PM
04DevilR1's Avatar
04DevilR1
Default Rear Wheels Spacers
Does anyone know where I could find spacers for the rear wheels (a little less than an inch maybe). I would like to see the stock wheels flush with the body of the rear fender, does anyone have any pics of your cars like this, with the thinkspokes preferably? thanks
Old Jun 1, 2008 | 09:00 PM
divitasbluepitbulls's Avatar
divitasbluepitbulls
I don't have pics but I got my spacers at Pep Boys. It is a multi-fit car spacer. It works great on mine and I think it gives me a 3/4 inch extra space.
Old Jun 1, 2008 | 09:02 PM
04DevilR1's Avatar
04DevilR1
did you need to get new bolts?? It doesnt look like I would be able to get the lug nuts on with a big spacer
Old Jun 1, 2008 | 09:34 PM
04DevilR1's Avatar
04DevilR1
zam
Old Jun 2, 2008 | 07:27 AM
taz03's Avatar
taz03
I used 5/16 spacers on my buddies car to bring them flush with the wheel well. They were from napa. The only problem is the holes are elongated and you have to make sure the spacer is centered on the lugs or you will get a vibration.
Old Jun 2, 2008 | 07:39 AM
johncbourg's Avatar
johncbourg
St. Jude Donor '09
Doug Rippie Motorsports, Dont go the cheap route.
Old Jun 2, 2008 | 08:03 AM
AU N EGL's Avatar
AU N EGL
YES you need new ARP studs and hardened lug nuts if you use spacers.
I run a 3/8" CCW spacer on ARP studs,
Old Jun 2, 2008 | 08:23 AM
2000lambovette's Avatar
2000lambovette
Bought my first set there before flaring the fenders. Did not need longer bolts and flushed the tires pretty well.
Old Jun 2, 2008 | 11:58 AM
tiojames's Avatar
tiojames
Doug has 5/8" spacers and the hi strength lug studs to go with them. The cheapie fit all ones from the auto stores are not a good idea for a wide spacer. The hi strength lugs are needed also. Check the search deal on how to drill the holes in the backing plates so you don't have to take apart the hub to install them. I run them on the front of my vert to clear the big calipers.
Old Jun 2, 2008 | 05:37 PM
jdmvette's Avatar
jdmvette
Night Owl for life
you're saying you put on a 3/4" spacer and used stock wheel studs and the wheel still bolted on?
Old Jun 2, 2008 | 05:48 PM
Safedog's Avatar
Safedog
This the best, and safest, way to go, IMHO
http://riggedup.ecrater.com/product.php?pid=892552
Old Jun 2, 2008 | 09:28 PM
04DevilR1's Avatar
04DevilR1
thank you!!! those seem perfect
Old Jun 2, 2008 | 09:32 PM
2000lambovette
The spacers I bought were from pep boys and I had no problem with bolts. I do not remember how thick they were but it flushed the wheel and tire very nice. After I did my flared fenders I bought 18x12 wheels and bought a spacer with built in studs. I will try to find my old spacers in the garage and see how thick they were but my stock botls had plenty of thread. Perhaps the original owner had longer studs put in?
Old Jun 2, 2008 | 09:41 PM
Safedog's Avatar
Safedog
You will need to dremel off the last 1/4" of your hub bolts for this adapter to fit. (the last 1/4" is unthreaded anyway - and will not affect you in the future.)
This process will add about 45 minutes to your job, but is easy enough.
Old Jun 2, 2008 | 10:04 PM
jdmvette's Avatar
jdmvette
Night Owl for life
oh ok. i have done a 3/4 spacer and it needed much longer studs. i now run a 5/8".
Old Jun 3, 2008 | 05:49 AM
04DevilR1's Avatar
04DevilR1
so you did this with the stock wheels? do you happen to have any pictures of how far the wheel sticks out with the 1" spacer?
Old Jun 3, 2008 | 08:57 PM
3whit's Avatar
3whit
This is what you need It is a 1 inch adaptor which bolts to the hub ,then the Wheel bolts to it . they are hub centric and lug centric for perfect alignment . Here they are on my car with stock size C6 wheel, Flush with fenders no clearance problems. They are available from Riggedup-Adaptors aircraft aluminum 59.95 for the pair .
Hope this help you out Check out the web site..
To Rear Wheels Spacers
Old Jun 3, 2008 | 08:59 PM
Safedog's Avatar
Safedog
Mine looks just like 3whit's - he taught me how to do and what to use.
Old Jun 3, 2008 | 09:09 PM
3whit's Avatar
3whit
works for me ,and you to I guess Thanks for the acknowledgment Safedog , +++++
Old Jun 3, 2008 | 10:31 PM
Quicksilver Vert 01's Avatar
Quicksilver Vert 01
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16
Are you using spacers on the front wheels too,or just the rears?
I have the same C6 wheels.The fronts look ok,but the rears need to
be spaced to be flush with the body.
