LS-1 operating temperature?
Old Jun 3, 2008 | 12:46 PM
killain's Avatar
killain
Oldtimer
Default LS-1 operating temperature?
What temperatures does your LS-1 run at? Mine has recently started to run at 220f in traffic and drops to 215f once moving. I was wondering what other C-5 vettes run at. Does a 180 degree thermostat lower the operating temps much? Thanks
Old Jun 3, 2008 | 01:43 PM
RyanR0101's Avatar
RyanR0101
Mine will hit 220-230 idling in traffic. Drops to 200 or so when I get moving. Try turning the a/c on. It's not the intuitive thing to do, but it turns on the second fan and will drop the temp fast. Don't fool with the thermostat. It won't lower your temps if you are too hot. It just opens up sooner.
Old Jun 3, 2008 | 01:54 PM
VinnyT's Avatar
VinnyT
You can use a 180 T-stat, but you also need to change your fan settings via Tuner or Handheld to be effective.
Old Jun 3, 2008 | 02:31 PM
GrayC5's Avatar
GrayC5
The temps you're seeing are within the normal operating range. The T-stat only determines the temp at which the cooling system opens up and the coolant starts to flow. It does not lower the operating temps or control how hot the coolant temp gets.
See the following thread that made the rounds here a short while ago:
Welcome to HEAT, what are your temps?
Old Jun 3, 2008 | 03:15 PM
Russ K's Avatar
Russ K
I have a 160*F stat, and lowered the cooling fan on & off temps. On the highway, the engine temp is ~172*F,
and in traffic, the engine temp is ~176*F-183*F.
Check for debris & bugs on the front side of the radiator.
Russ Kemp
Old Jun 3, 2008 | 04:36 PM
robsc501's Avatar
robsc501
Default ls-1 opreating temp.
HI There,
Yesterday the temperature was about 66 degrees outside kinda on the cool side.I was running 185 steady at highway speeds.I have a factory 186 degree stat. installed.In town traffic stop & go 195- 200 Check the front of your radiator for cleaniess
robsc501
Old Jun 3, 2008 | 04:45 PM
$BROKE$'s Avatar
$BROKE$
I get high temps also. In traffic with it being 90 some odd degrees out here in houston it will idle at around 220 and peak at 235. The fans come on and normally keep it around 225. When running on the freeway in the same weather it stays at about 192
Old Jun 3, 2008 | 05:52 PM
killain's Avatar
killain
Oldtimer
Default Engine temps
I guess the odd temperatures I'm getting seem normal, and the dealership said the same, but it just bugs me that all I did was change the coolant that the owners manual says to do at five year mark, and instead of running at 200 degrees to 210 which it has run at for the last five years in traffic, it now runs at 210 to 225 degrees. and all this simply by changing the coolant? i don't know it just seems to me as crazy?
Old Jun 3, 2008 | 08:07 PM
thetaxman's Avatar
thetaxman
mine runs @ 192-5 all day long, intraffic or out on the interstate
it never changes
and that is why I bought a real radiator
Old Jun 3, 2008 | 10:00 PM
burbleflyer's Avatar
burbleflyer
St. Jude Donor '08
it never changes
What rad and how much?
Old Jun 3, 2008 | 10:42 PM
Mine runs at about 195 out on the road and around 220 when idling in traffic.
Old Jun 4, 2008 | 08:58 AM
thetaxman's Avatar
thetaxman
BeCool and around 600 bucks
there are others that are good too for similar prices
Old Jun 4, 2008 | 09:20 AM
bucwheat's Avatar
bucwheat
220-230 is not uncommon.
Old Jun 4, 2008 | 11:56 AM
thetaxman's Avatar
thetaxman
and unnecessary
Old Jun 4, 2008 | 12:00 PM
FrankTank's Avatar
FrankTank
CI 7-8-9-11 Veteran
St. Jude Donor '06-'10, '13
Your temps are totally normal for a stock motor and stock tune. My car would get up to 225 and 230 (coolant temp) in stop and go traffic on a hot day.
Unless you plan on major engine mods (heads,cam supercharger etc etc) I would leave your stock t-stat in. Waste of money to change it. One thing you can do, just as a pre-caution, check your radiator and AC condensor....lots of stuff gets caught in between the two, these cars are low to the ground and are like vacums If you have a lot of junk in there, sometimes cleaning that out will help...but again you are well within the correct operating range.
Old Jun 4, 2008 | 12:07 PM
Quickshift_C5's Avatar
Quickshift_C5
Mine gets up to around 220 when sitting in rush hour traffic or the engine is idling. When I'm moving, such as cruising along the freeway or driving normally...it never gets above 176degrees.
Even when we were returning from a car show on a 95+ temp day on an 85mi return trip and getting the car up to 120mph a few times, it never went above 180degrees.
Old Jun 4, 2008 | 02:51 PM
ALVETTE00's Avatar
ALVETTE00
After a fan reprogram mine runs at 190.
Also...clean out the front of the radiator...all sorts of road debris can clog it up and affect it's cooling ability.
To LS-1 operating temperature?
