What is the point of this anyway? I can see that is obviously controls tire spin. Now, if I turn it off to "do a little tire spin", the torque management kicks in to limit this. WTF?
Now, I do NOT have Competition mode, so that argument is out.
I believe torque management limits torque during shifts, I could be wrong. I eliminated TM in my car and it will do a huge burnout during my 1-2 shift. I dont mean doing a burnout through 1st, Im talking from a roll.
I'm just curious to know why that button exists. (At least for my Vette, since I don't have Competition Mode.) What practical purpose would it make to keep it off, unless you're doing a burnout?
From: The smallest and most corrupt state in the nation. Rhode Island
Originally Posted by VinnyT
I do understand the basics, but I guess my question is why have a button at all? The only reason I see taking it off if for burnouts.
I figured that you knew the basics since you are a long standing member here.
I was just trying to answer the general question...
I have to admit, I DO see your point though.
I guess one could say that if you track the car, you may want traction control off so that you could use a little wheel spin to control or adjust your entry to or exit from turns...
Other than that.. yup, burnouts would be the only other use I guess.
The TC inhibits wheel spin whenever there is too much wheel spin or a difference in wheel speeds between the two rear wheels. If you start out in a straight line without any bumps TC will allow you to spin the wheels fairly liberally. However, if you hit a dip in the road with one side of the car TC can cut in even though you aren't really powering the car very hard (like in traffic at 5 mph). If you are autocrossing or road racing the wheel slip that occurs when cornering hard can cut power or cause a rear brake to be applied or both to keep a wheel from slipping even slightly. This really kills your time.
