Stock air filter element recommendations??
Old Jun 9, 2008 | 10:15 AM
C5nKY's Avatar
C5nKY
Default Stock air filter element recommendations??
I'm going to replace the air filter element. Its a stock box. Any recommendations on what element to purchase??
Old Jun 9, 2008 | 10:36 AM
Sinister-one's Avatar
Sinister-one
K&N, pricier than a stock replacement but worth the expense.
From this point on you'll never have to buy another air filter. Just clean and re-oil the K&N filter every 3-4 months and you're good to go !
Old Jun 9, 2008 | 11:57 AM
hotwheels57's Avatar
hotwheels57
S&B FILTERS (in CA) is another option. They're also cotton gauze which require a very light oil application. They include a small measured syringe to apply the oil rather than the aerosol application which owners tend to over use and contaminate the MAF.
They supply the after market with many of the filters used in after market air intake systems. A very good company to deal with with great customer service.
Old Jun 9, 2008 | 12:29 PM
Quicksilver Vert 01's Avatar
Quicksilver Vert 01
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16
Stay with the factory style pleated paper air filter.
Oiled cotton gauze filters can contaminate the fine wire element in the MAF sensor with oil residue.
Air flow gains,with cotton gauze filters,are
somewhat overrated too.
Old Jun 9, 2008 | 12:31 PM
DeeGee's Avatar
DeeGee
I've always used K&N and the cars still going strong
Old Jun 9, 2008 | 01:38 PM
RyanR0101's Avatar
RyanR0101
Mine is 10 years old and still looks good. I don't think you need to clean them much more than once a year or so though.
Old Jun 9, 2008 | 01:47 PM
jovette's Avatar
jovette
NAPA, WIX, and AC Delco, alll good paper filters. Suggest you stay away from Frahm. I like to get maximum filtration, so I also would never use an oil / gauze type filter element, I know others do, and that's fine, just not for me.
Old Jun 9, 2008 | 01:52 PM
Jacks02's Avatar
Jacks02
I use Fram and change it every 10,000 miles -- inexpensive and readily available. .
Old Jun 9, 2008 | 01:53 PM
gray-c5's Avatar
gray-c5
St. Jude Donor '08
Old Jun 9, 2008 | 04:35 PM
T VETTE's Avatar
T VETTE
Anybody know if the the stock Z06 air cleaner would be of any more help over my stock non Z06 car for '01 ??
Old Jun 9, 2008 | 04:40 PM
hotwheels57
...anyone care to place a bet there will be no consensus on the original question...again...
Old Jun 9, 2008 | 04:48 PM
Oldvetter's Avatar
Oldvetter
I use paper air filters, usually WIX. But, DELCO have proven to be GREAT air filters also.
I would stay away from oiled cloth due to: 1) possible MAF sensor oil contaimination, 2) they don't filter as well, 3) no real HP gains. Just mho.
Old Jun 9, 2008 | 04:59 PM
JH's Avatar
JH
Old Jun 9, 2008 | 05:08 PM
C5nKY's Avatar
C5nKY
Wix or Delco! Easy enough.
I am curious though about a previous question. Will a stock LS1 benefit from installing a stock Z06 airbox?
Old Jun 9, 2008 | 05:13 PM
IrishEd's Avatar
IrishEd
I am still under a GMPP Warranty, so I only use AC/Delco. Why give anyone a reason, to question a claim.
Old Jun 9, 2008 | 05:27 PM
Jet-Jock's Avatar
Jet-Jock
Old Jun 9, 2008 | 06:10 PM
Oldvetter's Avatar
Oldvetter
Yes, especially the early C5 years (use 2002 or later ZO6). It is $50-60, sounds better too, plus no water issues. After 2001, not much difference.
To Stock air filter element recommendations??
Old Jun 9, 2008 | 07:01 PM
tlgarst's Avatar
tlgarst
That's what I did, flows better. 02-04 Z06 lid is the ticket if you want to look stock.
Old Jun 9, 2008 | 07:09 PM
hotwheels57
What paper filter is used in all of the after market air intake systems?
(it's a trick question )
Old Jun 9, 2008 | 08:37 PM
Chemdawg99's Avatar
Chemdawg99
St. Jude Donor '12 thru '21
Here's my take:
There are three basic types of air filters: Pleated paper, oiled foam and oiled gauze.
Paper flows extremely well when new, but drops off quickly as it becomes dirtier and dirtier because it has almost no depth. Paper usually cannot be cleaned and is expensive to replace for the life of the vehicle. Everyone like Fram, Wix and STP make paper air filters.
Foam flows about as well as paper, but because it has depth, it can hold more dirt between washing and re-oiling. It's economical because it can be washed with detergent, dried and re-oiled over and over again. Amsoil and Uni make foam filters.
Gauze flows extremely well - better than paper or foam, but is usually less effective at trapping particulates, allowing smaller particles to enter your engine causing premature wear. Gauze can also be washed, re-oiled and re-used over and over again. K&N typically makes gauze filters.
The brand of paper filter is not extremely important since it will have to be changed frequently anyway and most if not all meet manufacturer standards for quality.
If your goal is high performance, then the K&N gauze filter is the way to go. However if your goal is longevity, then the foam filter is the way to go. The paper is easiest (simply throw it away) but is less economical in the long run.
You decide what works for YOU
