[Z06] Coating (ceramic) or no coating?
Old Jun 9, 2008 | 01:39 PM
glamcem's Avatar
glamcem
Default Coating (ceramic) headers & longevity of the engine
i searched but couldn't find a good answear
I'm thinking to get an
ARH headers and x-pipe and i'm told that i wouldn't be able to use my oem heatshield with any kind of aftermarket LTH .. so it seems like coating the header might be smart move in terms of lowering the engine heat , i don't really care how "cool" it'd look .. could that be any bad for the engine? is there anything i should know or i should just go ahead and have them coated before i install ?... if yes , should i also do the same for my x-pipes or header would be enough? thanks for your input
Old Jun 9, 2008 | 01:50 PM
Millenium Z06's Avatar
Millenium Z06
Moderator
Dollar cost perf per gain is minimal if at all. I do not notice anymore heat now than I did without headers; most ppl do not coat them esp if they are 304 SS.
Old Jun 9, 2008 | 02:06 PM
glamcem's Avatar
glamcem
^^ thanks i never thought about that gain , it should be minimal if any ..my main concern is the longevity of the engine and headers
Old Jun 9, 2008 | 02:13 PM
Millenium Z06
Moderator
304 SS will probably outlast the car.
Old Jun 9, 2008 | 04:47 PM
hotwheels57's Avatar
hotwheels57
Here we go again...I just used "ceramic metallic coating" as keywords (search) and came up with two pages of various opinions.
It's another topic where there will never be a consensus of opinion...
Old Jun 9, 2008 | 06:32 PM
vsocks1's Avatar
vsocks1
I agree.....but I just can't understand why there isn't more solid information to support one versus the other.
Old Jun 9, 2008 | 07:04 PM
hotwheels57
For the same reason there's so many different opinions about which is the best shifter, best clutch, best intake, best tires, best headers, best catback, best color, best wax, best wheels, yada, yada, yada.
It's all subjective and a matter of opinion...from the suppliers of the service/product and those that have used the service/product. And few owners will admit they made the wrong choice.
Personally, I wouldn't buy headers w/o a ceramic metallic coating, irregardless of the host material the headers are manufactured from. I like it more from the lifetime appearance standpoint and the heat reduction under hood.
I question why some questions are even asked anymore...unless the original poster is simply counting the totals of different opinions.
Old Jun 10, 2008 | 12:39 PM
JimbeauZ06's Avatar
JimbeauZ06
As said elsewhere it's a matter of opinion, personal preference, and what you want to spend money on.
Just don't let anyone convince you that your car will fall apart if you don't do it.
Old Jun 10, 2008 | 01:00 PM
glamcem's Avatar
glamcem
^^ thanks for the info , btw like i mentioned above i searched it but couldn't find a solid info
Old Aug 6, 2018 | 05:51 PM
C6_Racer_X's Avatar
C6_Racer_X
I generally have headers coated with a thermal barrier coating inside the pipes. The outside can be left uncoated or coated with whatever color you like. I would seriously consider getting the exhaust pipes after the cat coated inside as well.
Old Aug 6, 2018 | 06:19 PM
grantv's Avatar
grantv
In theory it adds power. Measurable? Not that I'm aware of.
It will reduce underhood temps which means less likelihood of cooked wires, rubber.
That said I've run steel and stainless headers in many daily driven cars for 35+ years, no special coatings, and no premature wire, hose, seal issues to my recollection.
Old Aug 6, 2018 | 07:45 PM
zeevette's Avatar
zeevette
I've had SS headers on my car for 15 years without any issues. I would recommend cool sox to shield your plug wires.
Old Aug 6, 2018 | 08:07 PM
Mike98SilVert's Avatar
Mike98SilVert
Active Streak: 90 Days
Ceramic coating is essential for keeping the under hood temperature cooler and for a nicer appeaarance too. My headers are ceramic coated. I also have heat socks for the spark plug wires and reflective heat protection for the starter wires and the brake lines along with reflective heat tape for electrical connectors.
To Coating (ceramic) or no coating?
