Help needed!!
Old Jun 12, 2008 | 09:50 AM
Munky's Avatar
Munky
Default Help needed!!
When I turn my AC on, I get a blast of horribly smelling air. My mechanic just called to tell me the heater box is clogges with Leaves, and the smell is coming from bad water that is trapped in this box.
The issue is that to remove and empty the box he needs to take the dash, steering column, and engine intake off the car.... $1400???
Does this seem right? I have never heard of anything like this.
Old Jun 12, 2008 | 10:13 AM
bucwheat's Avatar
bucwheat
Nor have I,shoot some Febreeze in the vents,If the car sat awhile some moisture may have accumulated in the vents and molded.
Old Jun 12, 2008 | 10:21 AM
Munky's Avatar
Munky
The mechanic said he tried draining the box, and can see leaves in the box, but can't get to them to pull them out.
I have never heard anything like this so I am puzzled.
Old Jun 12, 2008 | 11:00 AM
Quicksilver Vert 01's Avatar
Quicksilver Vert 01
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16
Run Forrest Run!!!!..........Far away from that mechanic!!!
Remove the blower motor and fan from inside the car to clean out the leaves and rotted debris. Spray some disinfectant in the air box before you reinstall the blower.
Old Jun 12, 2008 | 11:11 AM
00 Rooster's Avatar
00 Rooster
St. Jude Donor '08
This would be my thought too!!! Save your money. Good luck
Old Jun 12, 2008 | 11:25 AM
Munky's Avatar
Munky
You guys are the best. Can someone guide me on this, or provide me with a resource to read?
Thank you very much!!!! I am fairly mechanical, but know nothing about AC, or even where the box is....
Old Jun 12, 2008 | 11:28 AM
DeeGee's Avatar
DeeGee
PM me with your e mail and I'll copy the pages from the manual for blower motor replacement. They show the removal and replacement procedure. Looks like a 20 min job. I'd take the $1400 for that
Old Jun 12, 2008 | 11:37 AM
DeeGee's Avatar
DeeGee
You have mail
Old Jun 12, 2008 | 12:24 PM
Munky's Avatar
Munky
OK, I talked with my mechanica again. He has already tried taking the blower motor off, and going that route, but the leaves are back under the heater core, clogging the drain which he can't reach.
any other suggestions?
Old Jun 12, 2008 | 04:31 PM
Quicksilver Vert 01
You need to get creative here. Try a shop vac adapted with some smaller diameter flexible tubing on the suction end.
It might take a little time to suck the debris out in small bites,but it's certainly worth trying. Good Luck.
Old Jun 12, 2008 | 06:00 PM
BOTYNV1's Avatar
BOTYNV1
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19
for $1400 you have time and creativity on your side. Go the blower motor route and try anything(contraption) you can weasel in there to remove debris. Worst case scenario post about removing all the shop was going to and DIY, money well saved. I'm sure someone would be willing to impart their first hand knowledge of that.
Old Jun 13, 2008 | 11:50 AM
Munky's Avatar
Munky
I am going to attack this over the weekend and see what happens. I will keep you posted. If anyone has any suggestions, please post.
Thanks.
Old Jun 13, 2008 | 12:06 PM
c5streak's Avatar
c5streak
Can't add any more than everyone else has suggested except for this. When you get the airbox cleaned out, make sure you clean the "udders" on the firewall. That will cause some of the water and debris that started your troubles. I suggest you read Bill's sticky if you haven't already.
http://forums.corvetteforum.com/show....php?t=2032925
EDIT: I did have an idea. If you can get an air hose with a long tube on it, you might be able to "backflush" some of the crud out, by blowing into the A/C condensate drain on the firewall. Just make sure you cover your carpet and seats with something, in case it actually works, lol. Wouldn't want the crud in your upholstery!
Old Jun 13, 2008 | 12:44 PM
Quicksilver Vert 01
I like that idea too.
Old Jun 13, 2008 | 03:50 PM
Munky's Avatar
Munky
THanks for all of the suggestions. I will post my success/horror story on Sunday.
To Help needed!!
