problem with HUD bezel
Old Jun 12, 2008 | 09:54 PM
C5Vette168's Avatar
C5Vette168
St. Jude Donor '08
Default problem with HUD bezel/Dash Pad
I just noticed that the bezel from my HUD is starting to separate from my dash. My 2000 FRC came with the HUD installed from the factory. Here is a pic below (1st time posting a pic). Anyone else have this problem? Is there an easy way to fix this?
Old Jun 12, 2008 | 11:17 PM
C5Vette168's Avatar
C5Vette168
St. Jude Donor '08
bump ^^^
Old Jun 13, 2008 | 01:41 AM
C5Vette168's Avatar
C5Vette168
St. Jude Donor '08
Am I the only one with this problem on a factory installed HUD? I am hoping that this will be an easy fix as opposed to having to tear apart the dash. Bueller, Bueller???
Old Jun 13, 2008 | 01:44 AM
DeeGee's Avatar
DeeGee
Looks like you're missing a trim piece
Mine has a trim all the way around the seam. I'll see if I can find a pic
Old Jun 13, 2008 | 01:49 AM
DeeGee's Avatar
DeeGee
This is the best I can find but can you see the raised trim piece?
Old Jun 13, 2008 | 01:54 AM
C5Vette168's Avatar
C5Vette168
St. Jude Donor '08
Thank you for posting. I can see the trim piece. If anyone has a pic from the front, that would be great. A part number for this trim would be much appreciated also.
Old Jun 13, 2008 | 02:17 AM
DeeGee's Avatar
DeeGee
Heres a pic from above I just took.
On a second look it may be just that your dash pad has been badly cut or the trim has slipped. Hard to see from you original picture.
Old Jun 13, 2008 | 10:33 AM
PaceThis's Avatar
PaceThis
Looks like your bezel is fine, but heat has probably caused the slip...
Unfortunately, you're going to have to remove the dash pad to attempt a fix, no way around it. If you're lucky, you can simply adjust the bezel and reinstall. More likely, looks like you'll have to slot the holes holding it, and reinstall about 1/4" closer to the steering wheel.
Best of luck!
Josh
Old Jun 13, 2008 | 10:42 AM
C5Vette168's Avatar
C5Vette168
St. Jude Donor '08
Hi Josh. Thank you for the info. I was thinking that the heat was causing my dash area to warp, and maybe that my sunshade was somehow contributing to the bezel shifting. Someone mentioned that you have detailed install instructions for HUD. Do you have it posted online somewhere? Also, do you know anyone in SoCal that can help me repair?
Old Jun 13, 2008 | 08:25 PM
Warp Factor's Avatar
Warp Factor
Looks like the outer skin on the dash is shrinking.
Did you ever use Armor-All on it?
Old Jun 13, 2008 | 08:31 PM
C5Vette168's Avatar
C5Vette168
St. Jude Donor '08
I rarely use it. Maybe twice a year. Is it good or bad for the dash? I use a sunshade everyday also. Wow, can that really happen? Yikes.
Old Jun 13, 2008 | 08:38 PM
C5Vette168's Avatar
C5Vette168
St. Jude Donor '08
I also noticed that my dash above the VIN visible through the windshield is shifting forward. What the hell?
Old Jun 13, 2008 | 11:08 PM
C5Vette168's Avatar
C5Vette168
St. Jude Donor '08
bump to the top^^^. Need to know if this can be fixed, how to fix, or if I need to buy a new dash pad.
Old Jun 14, 2008 | 12:47 AM
BrianWe's Avatar
BrianWe
Very wierd. Good luck.
Old Jun 14, 2008 | 01:06 AM
C5Vette168's Avatar
C5Vette168
St. Jude Donor '08
Thanks. I love my car, but the annoying problems are starting to test my patience.
Old Jun 14, 2008 | 04:56 PM
C5Vette168's Avatar
C5Vette168
St. Jude Donor '08
Not sure of how to adjust the HUD bezel. I guess I am going to search for a replacement dash pad or buy a dash cover (yuck). Never liked dash covers, but at least it might prevent further damage to my dash. Thanks to everyone that helped me.
Old Jun 16, 2008 | 02:53 PM
PaceThis's Avatar
PaceThis
Per above
More likely, looks like you'll have to slot the holes holding it, and reinstall about 1/4" closer to the steering wheel. It's a fixable problem, it's just going to take a few hours of ingenuity to get it right.
Oh, and yes, that could easily be caused by Armor All...
Old Jun 16, 2008 | 03:47 PM
Chevy Guy's Avatar
Chevy Guy
Did you get the car wet? You know Corvetes melt if they get wet right?
OK, jokes aside. Pull the dash pad, its likely a very easy fix w/ some epoxy. Once you have it off it will be very easy to see what you need to do.
To problem with HUD bezel
