Column Lock.......quick question
)Howdy, have 2001 6 peed...
Last night I Parked at the store, turned ignition key, got
"remove key wait 10 second" message, and the steering wheel locked.
I jerked the wheel a few times, turned the key and it released,
and I drove it home....
Never happened before in 7 years, is this likely to happen again ?
I searched the best I could on here, and I'll order the Bypass from Houston later today, just curious what causes this ....
The cause? A poor design, plain an simple. With all of the positive things about the C5, this is one of the few negatives, and it amazes me that GM has never come out with a proper fix for it.
roscoe
Get the CLB and, oh yea, spend more time on this Forum.
If you want to read more, check the sticky in C5 tech. It has way more than you ever wanted to know about the column lock problem - including GMs efforts to fix it (3 times) and now their ddecision not to complete safety recall work under warranty.
. Will the CLB from Corvettes of Houston still work even if the recall has been done ? Does anything that GM has done so far in the recall have to be undone for the CLB to work properly? Is the CLB hard to install?
