I was just wondering if anyone has experienced a similar problem.
I have an 02 A4 with the standard 2.73 gear ratio. The problem I'm having is that when I'm on the highway cruising at normal speed (55-75 mph) and I go to pass someone, I hit the throttle and the transmission downshifts, starts to accelerate then cuts out as if I never hit the pedal. I immediately hit the pedal again and the car downshifts and takes off like a son-of-a-gun! It doesn't do this everytime, but has happened to me twice this week.
The only mods I've done that could be related are a Vararam and a velocity stack. The install of both was done about 6-8 weeks ago.
Any Codes ??? Is Trac Control Off Or On As A Defect In That Circuitry Could Cause The Throttle And Eng. To Cut Out.good Luck To You Its Scary When These Cars Go Out Of Whack,big Bucks To Repair Trannys,and They Can Tell Guys Like Me Anything And I Dont Have The Knowledge To Debate Em. Again Best Of Luck For A Timely And Inexpensive Repair.....
Personally I'd take the car to have it tuned (dyno). The shift points will be adjusted, among other things, and you'll feel like you have a new car. I have an A4 (3.15) as well and on my initial tune, CAI only mod, went from 283 rwhp to 312. You should also consider different gears. You'd notice a nice improvement with the 3.15 and even more so with a 3.42 - my next mod.
