LED Lighting
Old Jun 16, 2008 | 03:35 PM
  #41
johnathanrn's Avatar
johnathanrn
ok ill write it up no prob!! just if someone coudl let me know how i can add the pictures so they show up here and how to type the text either above or below the picture, then ill get started asap!
Old Jun 16, 2008 | 03:45 PM
  #42
FreddyG's Avatar
FreddyG
Very Nice job and an interesting idea! I like it!
If you want to type it up and send the pictures, I'll try to put it together and post it up for you.
I'm curious to see it!
Old Jun 16, 2008 | 04:21 PM
  #43
johnathanrn
whats ur email?
Old Jun 16, 2008 | 05:38 PM
  #44
tstar's Avatar
tstar
St. Jude Donor '11-'12-'13-'14-'15
Tim
Old Jun 16, 2008 | 05:47 PM
  #45
FreddyG's Avatar
FreddyG
Originally Posted by johnathanrn
whats ur email?
pm sent.............
Old Jun 17, 2008 | 01:56 PM
  #46
johnathanrn
oks o im writing it up right now... luvmyc5 if you still want me to email it to you just let me know.. wante dto see this through myself to the end. give me a couple of min. thanks all
Old Jun 17, 2008 | 02:48 PM
  #47
johnathanrn
Ok so heres the install DIY!!! I will be posting up the easier way of installing the led lights. By easier i mean you dont have to take the whole door off or speaker covers off. Dont pay attention to some of the pics where the door is off. I took the door off the driver side because thats the side i started on then realized theres no need to take off the door. First of all the equipment you will need. Total install time is probably about 45 minutes.
EQUIPMENT-
1- a corvette!
[IMG][/IMG]
2- a hangar or something similar to help thread the wire through
3- electrical tape.
4- a scissor or wire cutting tool to splice into the footwell lights.
5- any LED... i used a 15" LED flex light made by PILOT. I purchased it at autozone. It is super thin and fits under the door with no problem or rubbing!
6- some clear silicone if you really want to seal up the little piece of exposed wire that is present at the end of the install.
STEPS-
1-Open the door and get down under the door. You will see a square rubber piece. Just go ahead and pull it off. This will reveal a square shaped hole that goes right up inside the door.
2- Lower your windows.Using a hanger, straighten it out by untwisting it. Wrap the end of the flex light electrical wire to one end and secure it with tape. This way it doest slide down the hanger. Slide the end of the hanger that has the wire taped on in through the hole. Your going to have to feel around and find that smallish hole where you can put the hangar through. Its kind of at an angle right next to the metal washer thats there. You will realize if you have gone through the wrong hole if the hangar keeps going towards the door hinge (this is evident by the hanger not being able to advance anymore). Look at step 3 before continuing.
3- Now get the hangar started upward towards you. Take it easy and careful not to scratch the window as it is right there. To make it easier to see where the hanger is pull back the rubber molding that is at the edge closest to the door hing. By pulling it back you can see the hanger and which way its going. In this photo it shows the wire pulled through the top and at the very far upper right is that rubber molding piece that you can pull back on a bit to get a better view inside the window of the hangers progress.
3-So now you have the flex light LED part on the bottom of the floor and the end of the wiring towrds the top. Go ahead and pull the wiring through pretty much all the way.
4- Next step is to put the wiring through the accordian piece of rubber thats in the door hinge so you can pass the wire inside the car. Go ahead and pull off ONE side of this rubber accordian piece. DO NOT pull of the whole thing as it will make it difficult to put back on.
5-Now using your hanger again, bend it so that it will help pass the end of the wire as much through the accordian fold as possible. This part is a bit tricky as its pretty much a 90 degree bend. Get the hanger with the wire through as much as possible. Now you will need to look inside the car and up to the side where the rubber accordian piece comes into the car. Behind a piece of plastic with some foam on it is a big flat square piece of rubber. Pull this out a bit and rub your hand up to feel for the accordian piece of rubber. Go ahead and stick your hand/fingers in there and feel for the wire/hangar.
6-Once you have a hold of it pull it through all the way.
7-Next step is to splice it into the footwell light.
8- Just go ahead use a flat head screw driver to pop it off on one side and pull gently down. If you pull to hard like I did and the light comes off its wires, its no prob. Just unbolt the plastic piece thats right above your head and you will see a orange wire and a black wire. These will be the wires for the footwell lights.
THIS is what it will look like if you pull to hard. Dont worry because the wires are right there.
9-Next you will have to splice the LED wires into the foot well lights. I just cut the wire right at the footwell light. Basically cutting out the footwell light. Take the LED WIRE that has NO SILVER STRIPE and attach that to the BLACK wire of the footwell light, this is your ground. Next take the LED WIRE that has the SILVER LINE on it and attach that to the ORANGE WIRE of the footwell light, this is your power line. As soon as you do this they might not turn on. This will happen because you left your doors open for too long maybe. Close the door, lock it and open it back up. They shold turn back on. If they still dont then that means its too bright out and the lights wont turn on until it gets a bit darker. A great way of testing out to see if the lights work is by looking at the map light under the rear view mirror. If that map light is on then your LED lights should be on. You can also turn on your interior lights manually buy turning that **** thats on the far right corner of the dash board. P.S- Make sure to wrap up the ends in electrical tape.
10- Now that the lights are in and wrapped in electrical tape go ahead and start putting everything back. Tuck the wires away from view first. Put back the flat square rubber piece inside the door, the accoridan rubber piece on the door hinge. DO NOT PUT BACK THE flat square piece of rubber that is on the bottm of the door yet.
11- Measure where you want to put the actual LED LEX light. I put mine as far towards the door hing as possible. The felx light is 15" so its pretty long. I tested out placement of the LED light at night before i secured it to the bottm of the door. It really makes no difference if you put the light towards the door hinge or towrads the open end of the door. Once you have it place where you want go ahead and put that black peice of square rubber back in its hole.
12- This picture just shows where to put it. Place the LED flex light more towards the inside of the car. THE OPPOSITE SIDE OF WHERE IT IS IN THIS PICTURE. Towards the other weather stripping. this gives as much light possible to where you will step and gives a excellent cut off beam on the outer edge of the door towards the street.
13- BEFORE YOU ATTACH THE LED LIGHT using the double sided tape adhesive that it has, make sure you clean the area VERY WELL. I used alcohol to wipe the area down. Once you have cleaned go ahead and peel off the tape and stick it on. Remember get as close as possible to the inner edge of the door. Place it SLOWLY and run your fingers over it while pressing down to secure it.
14- Make sure that all your wires are hidden. its nice not to see ANY wires!! Looks like a professional install haha. You can now use the clear silicone if you want to put some on the little piece of exposed wire that runs to the led flex light and some on the aquare rubber piece that the wire runs into. Also you cant see the LED lights because they are so thin so it looks like the lights are built into the door!
15- Just repeat these steps for the other door and you are done!!! If anyone has any questions you can pm me here, email me at judge360@aol.com or you can call me if you want. Should I give out my cell numebr here? is it safe? Again, if you are in the long island/Queens area I would be glad to meet up and help anyone out. GOOD LUCK!! Trust me when your done youll be proud of how good it came out!! IF you want to see more install pics heres my photobucket http://s249.photobucket.com/albums/gg220/johnathanrn/
Old Jun 17, 2008 | 03:18 PM
  #48
BrianWe's Avatar
BrianWe
This thread is making it to resist the urge to add more LED's to my car
Old Jun 17, 2008 | 04:40 PM
  #49
FreddyG's Avatar
FreddyG
From the Great write up that you just did, you Definitely don't need my help!
Thanks for sharing the info and you did a Great job!
Old Jun 17, 2008 | 05:00 PM
  #50
johnathanrn
thanks... it means alot to hear i did a good job lol... well my favorites step of all is still step #1 haha.... im sure they make red and white and green color led's.... i thought of using white but i wanted the blue coloring... the blue is bright enough.. so i would imagine that the white should be pretty darn bright lol.
Old Jun 17, 2008 | 05:06 PM
  #51
FreddyG's Avatar
FreddyG
You're Welcome!
I wanted to try white because I'm getting older and can use all of the light that I can get!
Old Jun 17, 2008 | 06:56 PM
  #52
jdmvette's Avatar
jdmvette
Night Owl for life
great writeup jonathanrn.
i did a small homage to this thread myself.
http://forums.corvetteforum.com/show....php?t=2054692
Old Jun 17, 2008 | 08:15 PM
  #53
rpm462's Avatar
rpm462
Great write-up...ended up doing this mod myself today!
Old Jun 17, 2008 | 08:38 PM
  #54
jaxvet's Avatar
jaxvet
Very good writeup & great effect. Now I have something else that I have to do to the car.
If you guys don't stop this stuff, I'm not gonna have any time to drive it!!
Cool idea really like it & will be doing it.
Jack
Old Jun 17, 2008 | 09:09 PM
  #55
brian ns04's Avatar
brian ns04
Johnatharn great mod and thanks for the pics and writeup.
Is there a source for these in Canada?
Old Jun 17, 2008 | 10:02 PM
  #56
stormrider's Avatar
stormrider
Excellent idea and DIY write up
Old Jun 18, 2008 | 04:00 AM
  #57
johnathanrn
i like that door handle mod jdmvette!! i have a couple of ideas that are bouncing around my head... im going to go through with them and if it looks good ill post up another write up lol.... umm... im not sure if there is a source for those in canada but there def. should be. They are L.E.D flex lights... the company that i brought them from is named PILOT... and i bought them at the local autozone. is the write up too long, too many pics?
To LED Lighting
Old Jun 18, 2008 | 10:46 AM
  #58
FreddyG's Avatar
FreddyG
No such thing as too long or too many pics!
Old Aug 11, 2008 | 05:52 AM
  #59
Choreo's Avatar
Choreo
Great write-up!
Does anyone know if Pilot makes these in longer lengths? I cannot seem to find any sources on the Internet?
Old Aug 11, 2008 | 09:59 AM
  #60
JW Motorsports's Avatar
JW Motorsports
Banned Scam/Spammer
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17,'19,'22
I did this mod two days ago. It looks really good.
