Header install help
Old Jun 19, 2008 | 03:43 PM
iurutherford's Avatar
iurutherford
Default Header install help
The headers, xpipe and exhaust are going on tomorrow. The only part I'm sweating installing are the headers. Can anyone offer advice or have a link to a step by step for header removal and installation? This will be done on jack stands, not a lift so I'm sure that will throw some added fun my way! Any tips will be helpful and appreciated. Thanks in advance.
Old Jun 19, 2008 | 04:11 PM
Berger6696's Avatar
Berger6696
here's a link to Cajundude's LGM long tube header install. Good luck!
http://www.cajundude.com/longtubes.htm
wanna do mine next?
Old Jun 19, 2008 | 04:50 PM
rpm462's Avatar
rpm462
I did mine on jack stands, installed AR headers and wasn't bad at all. Just took my time and if ran into an obstacle just took a step back for a few minutes and then tried again. I do highly suggest only loosely bolting them to the heads until you get the x-pipe bolted up too. Good luck.
Old Jun 19, 2008 | 04:56 PM
rws.1's Avatar
rws.1
here is a link to another how to...
http://www.ls1howto.com/index.php?article=29
Old Jun 19, 2008 | 05:05 PM
Jeff @ TPE's Avatar
0Jeff @ TPE
Former Vendor
St. Jude Donor '06 & '12
The most important piece of info is the manufacturer.
That will aid ALOT in who their installed..
But as always, Cajuns install manuals is it ****..
Old Jun 19, 2008 | 07:20 PM
ProgGod's Avatar
ProgGod
Which brand are you installing?
Old Jun 19, 2008 | 11:00 PM
iurutherford
I'm going with the Dynatech supermaxx headers. They look great sitting next to the car! It looks a little daunting but the write ups you guys posted will be a tremendous help no doubt. Thanks a million!
Old Jun 19, 2008 | 11:17 PM
OleStraightStick's Avatar
OleStraightStick
St. Jude Donor '08
you'll do just fine... make sure the car is safe and secure on them jackstands! take ur time and dont try to force anything.. when you get frustated and start tearing up your knuckles, sit back and have a beer
Old Jun 20, 2008 | 12:51 PM
iurutherford
Sounds like the best advice I've heard all day!
Old Jun 20, 2008 | 01:01 PM
tellefan's Avatar
tellefan
Before you start taking your car apart, check and see if the 02 extensions have the right connector. Ask me how I know.......... I had to extend mine 24" by soldering in wire, using shrink wrap and plenty of tape. This alone will take about two hours if you do it right.
Other than that they fit perfectly. Follow the instructions that Dynatech sent with the headers and you'll be fine. If you have any other questions feel free to PM me.
To Header install help
