C5 02 sensor?
Old Jun 19, 2008 | 09:40 PM
claprood's Avatar
claprood
3rd Gear
Default C5 02 sensor?
I am getting intermittent errors on my 02 sensor(error code 1416 air system bank 2 ).Does anyone know how to check the sensor to determine which one is bad. I have heard that you can hook up an ohm meter between pins on the connector to weed out good from bad.What is strange is that initially the check engine light comes on, but when I check codes there is an "H" to indicate that everyhing is OK. I have reset several times ,but same thing happens every time.
