Help! I damaged my roof!
Old Jun 21, 2008 | 06:35 PM
jdub's Avatar
jdub
Default Help! I damaged my roof!
I need your help. My top blew off of my car today and i was able to retrieve it. Needless to say the top sustained scratches and damage on the corners. I have another tinted top that i can use now. How much am I looking to pay for repairs? I live in Delaware, so if anyone can advise me on the right direction relative to a a good bodyshop that can repair my top! Thanks in advance. I am pissed!!!!!
Old Jun 21, 2008 | 06:42 PM
AU Eagle's Avatar
AU Eagle
St. Jude Donor '08-'09-'10-'11, '14
Ouch! Another member of the Flying Roof Club.
Hope you get it all worked out.
Old Jun 21, 2008 | 06:59 PM
Mike2013's Avatar
Mike2013
St. Jude Donor '03-'26
What is so hard about latching the top?
Old Jun 21, 2008 | 07:00 PM
jdub's Avatar
jdub
Thank you!
Old Jun 21, 2008 | 07:04 PM
jdub's Avatar
jdub
there is nothing wrong with latching the top. I just forgot to do so. I am completely at fault! I will get it repaired if it's not to exspensive.
Old Jun 21, 2008 | 07:08 PM
TrplBlk01's Avatar
TrplBlk01
I have personally help my brother fix his by wet sanding it and clearing the whole glass top. Looks better then new!
Old Jun 21, 2008 | 07:54 PM
Mike2013's Avatar
Mike2013
I'm not ragging on you brother. It just seems that a lot of people here have a hard time remembering to latch the top. If you whip out your tool to take a leak, you remember to put him back and zip up your pants right? Same principal.
Old Jun 21, 2008 | 09:01 PM
Carz4Toyz's Avatar
Carz4Toyz
I also am right here in Delaware. Classic Auto Body does all Covettes and does insuance corvette work and they took care of me with my Viper as well. Ask for Earl, and tell them Steve "the Vacuum cleaner guy" sent you. Good luck, not that you'll need it you are in good hands. Sorry to hear about your top but they will make it all better.
Old Jun 21, 2008 | 09:08 PM
Gray Fox's Avatar
Gray Fox
CI 5-6-7-8-9 Veteran
St. Jude Donor '06-'07-'08-'09
Point taken...
It was an accident, they happen, let it go!!
Old Jun 21, 2008 | 09:45 PM
Rendell's Avatar
Rendell
Happens to the best of us. I lost my clear top (only one I have) and got a new one off a forum member. Good luck.
Old Jun 21, 2008 | 09:55 PM
jdub's Avatar
jdub
Thanks for the info. Do you have there address? I forgot to mention that the top was my hard top not my glass top. What was the average cost for repairs. Thanks in advance for your support.
Old Jun 21, 2008 | 10:12 PM
Ol'55's Avatar
Ol'55
From: Southern New Jersey, The wet part at the bottom
John, You aren't the 1st member to experience this in here. Don't be too hard on yourself. It's a good thing that you have the 2nd roof to carry you over 'till you find a replacement painted roof. My suggestion is to watch/post in the Parts For Sale/Wanted section, and check the CF vendors that salvage Vettes. Experience is the best teacher, don't ya think?
Old Jun 21, 2008 | 10:24 PM
TEXHAWK0's Avatar
TEXHAWK0
Hang a "Remove before flight" tag on the latch to remind you to check it.
Old Jun 21, 2008 | 11:03 PM
silverbullit99's Avatar
silverbullit99
Can't see how that can happen, are people in that much of a rush that they can't take the extra min and double check the latches... Well hope you can get a replacement at a good deal,, sucks to have that happen to anyone !
Old Jun 22, 2008 | 01:28 AM
Icewind Dale's Avatar
Icewind Dale
I have heard about this. I see where you could get sidetracked and forget to latch it. So i obsessively check mine. Hey just imagine if it was your only top! I dropped my top into my vette (I thought it was in the groove but it wasn't) and ripped the center console door. Stuff happens. Good luck!
Old Jun 22, 2008 | 01:56 AM
DeeGee's Avatar
DeeGee
Its a known problem. In the aviaton community we're briefed to be aware of situations where its likely to catch you.
You may not realize but every small serious of actions has a set pattern. Think about when you dry yourself when you climb out the shower or brush your teeth. You run through the same sub-conscious sequence. If youre interrupted its hard to get back into it and you miss something. Its call a Motor Neurone Pattern by the shrinks.
Air Traffic Controllers never interrupt pilots at the start of the descent without saying "interrupting checks". Its been known for such interruptions to result in landings without "Dunlops"
If you're closing up the car and someone distracts you or you deviate from a norm you can leave it unlatched. Easy. There are those that have and those that will.
There you go. You didn't expect a psychology lecture
To the OP, hope you get the roof fixed up. You're not the first but I suspect you'll not be the last even though that wont make you feel better.
Old Jun 22, 2008 | 02:12 AM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
How did it come off? Human error? Sorry about your top, I see them on the auction site all the time for around 250-350, Also check the C5 parts section here.
To Help! I damaged my roof!
Old Jun 22, 2008 | 08:58 AM
jdub's Avatar
jdub
Thank you! I agree!
Old Jun 22, 2008 | 09:09 AM
jdub's Avatar
jdub
Human error, I was on the side of the road when I inserted the top on car. I was waiting for my Wife who was driving my other vehicle one mile back, stuck in traffic. When I returned to the driver's seat she was quickly approaching, as she past, I safely entered the roadway. I did not want her to suddenly stop or quickly pull over to my location and cause an accident. After 50ft the sun had re-entered my cabin and my top blew off and tumbled in the roadway. I exited my vehicle picked-up my top placed it in my truck and drove away. Again, I thank you for your support.
Old Jun 22, 2008 | 09:11 AM
7thson's Avatar
7thson
Finding a top is the easy part. Matching Millenium Yellow is the trick. Good luck. Look at it this way, you will never forget again.
