Radio install questions
Old Jun 22, 2008 | 03:02 PM
JRyanKC's Avatar
JRyanKC
Default Radio install questions
I am considering purchasing a new radio for my 99 C5, its a dual din dvd reciever with a 7in screen. Currently have the stock radio, the factory bose system. Wanted to know how hard the install is? Will I need to make any modifications? And if anyone knows where I can get instructions on how to install it myself with out demolishing my dash.
Old Jun 22, 2008 | 03:03 PM
MagRedConv's Avatar
MagRedConv
Check out the Audio/Electronics section, lots of info
Old Jun 22, 2008 | 03:08 PM
DeeGee's Avatar
DeeGee
I posted a How To for fitting the AVIC N1 in post #18 on this thread
http://forums.corvetteforum.com/show....php?t=1817090
The idea for a double DIN is the same but you'll need to modify your bezel to take the 2XDIN size unit. C5 Kidd modifies bezels and there are a few others on the Forum who will do the mod for you. I'm afraid that for a Double DIN, dash demolishing is a given
Hope it works out
Old Jun 22, 2008 | 03:38 PM
Double D Mods's Avatar
0Double D Mods
Former Vendor
St. Jude Donor '12-'13
You will cut up not only bezel but the mounting cae as well
BEzel will need to be modified to fit the double din head unit
like this
after bezel is done...not eyou will need to loose ashtray in most cases(recommended )
you will also need to cut the brackets out of the mounting cage
I had the help of two forum memebrs for the rest of the install
read up in audio section and you can find alot of info i can also assist on bezel info as well
Old Jul 5, 2008 | 12:14 PM
BadChad's Avatar
BadChad
Hi C5 Bearsfan, this is it, I still have to get the Serius to work, and the cracks aren't too obvious I guess, can't get too picky here.
[IMG][/IMG]
To Radio install questions
