HVAC DTC's
Great reference for the DTC codes.
Your codes are both HISTORY codes. Means they have happened, but are not currently happening.
B0361=Left actuator short to ground
B0441=Left actuator out of range
When you start the car, the HVAC does a slef diagnostic. If it doesn't see certain parameters, it throws a code. Doesn't neccesarily mean there is a problem. Just that at THAT moment, it didn't see what it was looking for. If your AC works, then I wouldn't think twice about it. Clear the codes and go 'bout your day, without another thought about it.
Hope this clears it up for you.
