Column Lock
Old Jun 26, 2008 | 09:09 PM
K-9's Avatar
K-9
2nd Gear
Default Column Lock
I read the list of fixes but I think mine is different.
Its a 2002 Z06 and while it was getting a H/C kit it had the service column lock come on. It all ready had the column lock fixed at the dealer by the first owner. So the warning is still on but I can drive the car and don't get the fuel shut off.
Is this the fix i need to do? I got this from the help list.
4)MN6/M12 cars only - go into your passenger footwell, locate the relay added by the recall mod, remove the relay altogether and bypass the circuit as described below (my choice).
Any help would be great. Thanks
Kane
Old Jun 27, 2008 | 01:34 AM
DeeGee's Avatar
DeeGee
Sounds like you have one of the earlier recalls. There were three (4006 A B and C). Its 4006C that reflashes the computer with the fuel shut off.
If you're still driveable get a column lock bypass and it'll solve all your problems.
Old Jun 27, 2008 | 09:40 AM
itza56's Avatar
itza56
I just put in the CLB this last monday....
It took all of 40 minutes, and no more issues !!
also put in the shift skip bypass... Beautifull !!
Like driving a different car.
To Column Lock
