column lock info
Old Jun 29, 2008 | 07:59 PM
1danielson's Avatar
1danielson
5th Gear
Default column lock info
first off thanks MagRedConv directing me to the sticky tech site,it took me few mins to figure out how to get there.i take it that (man6,means 6 speed)and (a4 means auto)anyway i have 2001 -6 speed-after reading the owners manual,which is a2002 manual,i hit the reset button and it cleared the (service column lock)msg.so now after i start up i clear the fault and it doesn't come back on until i turn the car off and back on again.I'm wondering if i have to worry about ccolumn locking problems I've read about.
Old Jun 29, 2008 | 09:27 PM
Jet-Jock's Avatar
Jet-Jock
Order the bypass module from Corvettes of Houston. Install it takes about 20 minutes and your issue will be solved.
Old Jun 29, 2008 | 11:04 PM
Ol'55's Avatar
Ol'55
From: Southern New Jersey, The wet part at the bottom
St. Jude Donor '08-'09-'10
Do it now.
Old Jun 29, 2008 | 11:09 PM
at88mph's Avatar
at88mph
From: The artist formally known as NONO5.0 Mobile, Al
Originally Posted by Ol'55
Do it now.
Before its too late! www.corvettesofhouston.com
Old Jun 29, 2008 | 11:40 PM
I would go ahead and get a column lock bypass kit and install it on the car. Can the column lock on you without the bypass - in a word, yes.
Old Jun 30, 2008 | 01:13 PM
av8or's Avatar
av8or
I finished my CLB install less than an hour ago.... not quite as simple as some suggest, but not that difficult if you have good instructions.....and the instructions that come with the Corvettes of Houston kit are not very good. If you decide to do it yourself, use the following:
http://www.ls1howto.com/index.php?article=24
Much more detailed, with pictures.
Old Jul 1, 2008 | 05:12 PM
Jet-Jock's Avatar
Jet-Jock
Those are the best instructions. I found the hardest part being upside down with cervical disc problems and trying to manipulate in that limited space. If I can do it nearly anyone can.
Old Jul 1, 2008 | 05:37 PM
GRUNIE's Avatar
GRUNIE
It's an easy install.
Old Jul 1, 2008 | 09:51 PM
vsocks1's Avatar
vsocks1
To column lock info
